Close Loop-LT Trim Control Findings
Interesting! Thanks, Appauldd. I will try this one also see if it gives me more consistent AFR during WOT. My mid LTFT is about 2%, and LS is on. It seems my AFR is changing ~0.2 depending on the weather. (Leaner when cold)
I went down to 600Hz.
It's just where my car with a stock turbo hits minimum boost (12 psi) at the lowest RPM (2800) using the SD patch.
Every car is going to be different as altitude will have HUGE impact on HZ readings.
03whitegsr,
So you are saying that by setting the mid-high crossover point to 800Hz we can effectively make the LTFT always float to 128 or 0 instead of increasing and affecting AFR. I have an issue where my LTFT are affecting my midrange by a full point. I am going to disable leanspool as well but wanted to see if changing the mid-high crossover point is a better solution.
Setting the 800Hz has made a huge difference in the consistency of the pulls in my car. I have LS enabled for the safety it offers.
Give this a shot....you won't be disappointed.
Do I just add the following text to my XML or do I need to add the rest of the BFPW code that is in the advanced fuel control thread?
Also do you set both to 800hz?
<table name="Closed Loop - LT Trim Control Ranges" category="Fuel" address="3021" type="2D" level="1" scaling="LT Trim Hz">
<table name="Conditions" type="Static Y Axis" elements="4">
<data>Low -> Mid</data>
<data>Mid -> Low</data>
<data>Mid -> High</data>
<data>High -> Mid</data>
</table>
</table>
</table>
</table>
find your rom for this effort
https://www.evolutionm.net/forums/ec...m-control.html
</table>
</table>
</table>
</table>
thanks for the thread.
When I open, <data>Low -> Mid</data>
mid/low, low/mid numbers are the same, what should they read?
If you get all entries the same you may have loaded the wrong rom.
I think there was another thread about this a couple of weeks back. I recommended 800hz and did it a looong time ago
