Fuel Cut
Old Jan 7, 2010 | 09:34 PM
rolly1818's Avatar
Registered User
seems like ur fuel pressure spiked. check your pump wiring...and fuel pressure regulator if u have one.
Old Jan 7, 2010 | 11:56 PM
nabilsx's Avatar
from my experience, it seems fuel table with cell values below 10 are making the fuel injectors duty cycle very high, and that is causing the injectors to fail, I am trying to make the table as close to real life as possible, get a walbro, raise ur fuel pressure, maybe bigger injectors, when I tune, I try my best to avoid making the inj. DC go above 115%, by the way are u using a tephra mod file??
NAB
Old Jan 8, 2010 | 12:21 AM
nabilsx's Avatar
by close to real life i meant as close to a wideband reading as possible.
Old Jan 8, 2010 | 05:22 AM
hediki12's Avatar
and what do you do to achieve that if you dont mind sharing? because alot of tuners say the never match up or come close at times.
159% wow.... that realy high i back off the throttle at 95%... and never floored it past the "danger rpm" where it get high untill i get my injectors.
