Big thanks to scheides and mrfred for the help and comments to share ...
Old Feb 2, 2010 | 09:00 PM
freshevo8's Avatar
Well, after messing around for 2 1/2 hours trying to get the SD pre patched rom working I finally got it. A problem I ran into was trying to copy the omni 4 bar map sensor parameters into my Evo 8 ROM 96940011.xml file before I tried it into the pre patched rom and it didn't work. Mrfred told me it was prolly a vista permissions issue and when I unchecked the Ecuflash folder from read only.....it worked!
Then after copying everything over to the pre patched rom for the omni 4 bar and converting everything over to big maps I couldn't get the car to start. I went into the (FAA) bits and tried to disable immobilizer by hit the "=" key and inputing a "0" value and nothing happened. Then when I hit the "-" key and then it went to "0". Everybody might already know this but I wanted to post my mistakes in case others are not so computer smart as I am Now on to logging everything tomorrow and seeing what happens. If anyone doesn't want to post something fearing its a dumb question feel free to pm scheides as he was a big help and I'll also help in anyway I can.......
Old Feb 3, 2010 | 05:26 PM
bigric09's Avatar
also... if you read in that same area, instead of disabling your immobilizer, there is a hex address to type in for either 03 04 or 05 and then you can keep your immobilizer and the car will start.
Dont be afraid to call a brother man.... I'll BS with you about anything concerning this crap. The more we learn, the faster, the better off we both will be
Old Feb 3, 2010 | 05:37 PM
freshevo8's Avatar
unless your phone wasn't working I called you once last night and again today? ANSWER your phone focker!
Old Feb 3, 2010 | 06:03 PM
bigric09's Avatar
i havent seen a single missed call from you. I texted you tonight too asking if you are off the maf yet or still using it
Old Feb 3, 2010 | 06:15 PM
PeteyTurbo@KHC's Avatar
Good to know we have people aboard willing to lend a helping hand!
Old Feb 3, 2010 | 08:35 PM
freshevo8's Avatar
Don't make me show you my AT&T phone call logs online Maybe the Mrs. is hitting your silent button on your phone then when your not around! No worries. You know i'll be coming and asking lots of questions when everything gets installed and we put her on the streets. HOPEFULLY, everything gets here in the next 2 days as my first big shipment comes tomorrow. If it does, i'll be down at TBC getting the bung welded on for the iat sensor on the aftermarket uicp ASAP.....
Old Feb 3, 2010 | 08:38 PM
bigric09's Avatar
yep... how has the tuning gone so far ? Im waiting on this damn fuel rail to show up so i can swap injectors and my perrin rail that i sold out, get them dialed up and flash to SD to start playing around.
I should also be ordering the turbo setup friday i think... im going to rotate the tax check into play and use the money from the old turbo kit to back fill the taxes. If nothing else, the car will look nasty lol under the hood.
Old Feb 3, 2010 | 08:49 PM
freshevo8's Avatar
Tuning is easy because all I did was translate my old maps into big maps translator and transferred all this over too:
Injector scaling/latancy tables
Boost contrl/boost limit tables
MAF scaling
MAP sensor scaling
Immobilizer disable
My car has an exhaust mani gasket leak also and the car still idles and everything like a champ without rpms goin up and down like b4. I drove it today and had to adjust the jitter fix as it was noticable when cruising around 2200 rpm and thats about it.
Old Feb 3, 2010 | 08:50 PM
bigric09's Avatar
nice... have you unplugged the maf yet... thats when the real test comes in
Old Feb 3, 2010 | 08:51 PM
bigric09's Avatar
we need to get together and compare maps when its all over with...
i want to see what tables you are adjusting. Some of the things i have read on here, i dont have those tables, so i think the posts are just older
Old Feb 3, 2010 | 08:55 PM
freshevo8's Avatar
I have the async tables you were talking about earlier.
Old Feb 3, 2010 | 08:59 PM
bigric09's Avatar
i dont... i wonder if i missed something in the JCSBANKS thread. I didnt see anything. I just downloaded the same stuff everyone else did and copied it into my v7 rom, labeled it 88591715 and rolled out
Old Feb 3, 2010 | 09:07 PM
freshevo8's Avatar
For my rom it was easy as scheides already had a pre patched rom for the evo8. I just had to add the omni 4 bar definitions to the .xml file to get the map sensor tables to show up and that was about it. PM one of these guys with a 9 rom and ask them?
Old Feb 3, 2010 | 09:12 PM
bigric09's Avatar
i have made its own thread, got no replies, so i patched the crap myself and then posted it for everyone else to use. I just dont understand why those items dont show up for me. I copied the entire JCSBANKS download into the rom. Didnt miss anything. There is no reference to the asynch stuff.
Old Feb 3, 2010 | 09:26 PM
scheides's Avatar
EvoM Moderator
Woot! Glad you got it runnin on SD man! Post up pics of your build as the parts come in, should be a good one!
GLAD TO HELP but the credit has to go to tephra, phenem, mrfred, jcbanks, everyone I mentioned in my how-to thread.
