Switched to SD and have the craziest code ever?
Old Mar 4, 2010 | 12:07 PM
freshevo8's Avatar
Anyway, I'm getting a P0125 code which is "excessive time to enter closed loop fuel control". The car is running great, fuel trims are +/- 2 and this code doesn't want to go away. The tps sensor has also been calibrated correctly after installing 65mm tb. The ONLY thing I think could possibly be causing this is the "whistle" possibly that I get from my 65mm tb or maybe my Tial 50mm BOV. Everything seems to be running great so I don't know why it keeps coming up......
Old Mar 4, 2010 | 03:38 PM
dunk186's Avatar
search ecu flash, po125... i was throwing the same code, the local guy that tuned my car evo8dad on the forum, made several posts about it
Old Mar 4, 2010 | 03:52 PM
tscompusa2's Avatar
you sure thats the description of that code? google says:
A code P0125 may mean that one or more of the following has happened:
Insufficient warm up time
Low engine coolant level
Leaking or stuck open thermostat
Faulty coolant temperature sensor
http://www.obd-codes.com/p0125
Old Mar 4, 2010 | 04:03 PM
freshevo8's Avatar
the description I gave is the one evoscan gives you.....
Old Mar 4, 2010 | 04:49 PM
lan_evo_mr9's Avatar
You don't happen to have the table "min coolant temp for closed loop" do you? If that is set too high, say over 30*, then you can get that fault. I would get that fault and if I lowered that table to 30, I was good.
Old Mar 4, 2010 | 10:35 PM
JohnBradley's Avatar
The stock value is 7*
