Need help with HI OCTANE MAP V7 user
Old Mar 24, 2010 | 05:19 PM
C130flyer's Avatar
Whenever I log a pull the AFR holds nice and easy 11.5-11.7 until I hit 7000+RPM then it dips to 10.5
No matter how lean I make the fuel map it still dips down to 10.5 right after 7000
Anyone have any ideas
Old Mar 24, 2010 | 05:25 PM
nothere's Avatar
you have raised it by 6 tenths or so?
Old Mar 24, 2010 | 05:30 PM
donour's Avatar
Are you logging afrmap to verify that your changed cells are active?
d
Old Mar 24, 2010 | 05:43 PM
C130flyer's Avatar
could you please aplain afrmap? I normally don't log that nor do I know what it is.
Old Mar 24, 2010 | 05:57 PM
SeeCoryRun's Avatar
can you post the log?
Old Mar 24, 2010 | 06:04 PM
nothere's Avatar
afr map is the fuel map in ecuflash. evoscan logs the cells you hit. trouble is you still hit between the cells so you have extrapolated results sometimes
Old Mar 24, 2010 | 06:55 PM
Appauldd's Avatar
Are you running with Lean Spool enabled? If so, raise the stop limit to exceed your current rev limit.
Old Mar 24, 2010 | 07:34 PM
C130flyer's Avatar
ahhh that may be it kind sir!!!! I am running lean spool and I normally don't but with the new V7 I choose to keep it enabled LOL.
Applaud FTW
Old Mar 25, 2010 | 05:29 AM
SeeCoryRun's Avatar
what rom are you using for v7?
i know 94170715 doesn't have lean spool.
Old Mar 25, 2010 | 06:01 AM
Appauldd's Avatar
UM....yes it does.
Old Mar 25, 2010 | 06:11 AM
SeeCoryRun's Avatar
im wrong then, but 94170715 doesnt have the lean spool tables like 96530706.
not to thread jack, but how do you know lean spool is on or off if there are no tables for it?
cheers to Appauldd and your work on 94170715, car runs great!
Old Mar 25, 2010 | 06:15 AM
Appauldd's Avatar
I do not believe the XML you have is correct to show the Lean Spool tables. It appears there are several XML sets floating around.
Shoot me an email at the same SN as here at G mail. I will send you an updated XML that shows these tables.
Paul
Old Mar 25, 2010 | 06:22 AM
SeeCoryRun's Avatar
Paul
cool, thanks.
that might also explain why i cant pull up 94170715 xml for maptracer in evoscan, ive been having to load 9653 in order to get the scaling.
does this mean lean spool has been on the whole time and i just have no control, or just the version of v7 that i have doesnt have lean spool?
Old Mar 25, 2010 | 06:29 AM
Appauldd's Avatar
Load up the XML I sent you, then give it a look.
Old Mar 25, 2010 | 06:42 AM
SeeCoryRun's Avatar
AWESOME! orgainzed everything too compaired to the xml i was runnig.
