Injector faulty?
Old Mar 28, 2010 | 03:14 AM
veszett's Avatar
Injector faulty?
My fuel is tuned to run 11.6-11.8 WOT on 98oct and I had the occasional 1-2 knock counts. I use evoscan and log regularly. My multipiers are LOW 18 MID 20 HIGH 20.
Last week I went away on work for 1 week. When i got back i went for a drive and had some really high knock counts (4-9) mainly around 5500rpm (280-290 load) and up and also quite a bit after releasing the throttle with load around 120. the car feels great and pulls hard so im stumped. i logged again and found that my afr's are around 12-12.2 WOT. now nothing much has changed, weather is similar also.
Does this sound like an injector thats dying and causing the leanness?? or something else? i have stock injectors and IDC is between 92-102% at WOT. the smoothness of IDC and IPW in evoscan is not as smooth as it used to be. im not boosting till i sort this but i dont want to damage my engine, HELP!!
EDIT: One more thing. Knock voltage doesnt reflect knock sum counts are they usually do, they are sometimes under 1.0v even
Last edited by veszett; Mar 28, 2010 at 03:37 AM. Reason: Added knock voltage comment
Old Mar 28, 2010 | 04:28 AM
evonut270's Avatar
change your fuel filter would be the first port of call.also how long has your fuel pump been in? 12AFRs are fine i wouldnt worry about that too much.a knock sum of 4-9 is not that high a degree or 2 ignition will bring that down.you must be running around 1.8 bar boost for loads that high.
Old Mar 28, 2010 | 04:59 AM
veszett's Avatar
i installed a new walbro 255 about 2-3 months ago with the new filter on the end that came with the kit...is there another fuel filter?
i'll try adding a bit (0.2) more fuel and i've already taken 1* of timing out where im logging the knock which didnt appear to do anything. I always log knock voltage and it is relatively low now compared to when was tuning a few months ago and registering knock.
one of my coolant hoses ruptured a couple of days ago and i had all the coolant leak, lucky i was near home and engine was still coolish. initially i thought it may have something to do with engine temps being higher but dont think that has anything to do with it now since i fix it it still doing it. its just wierd that this started happening since i got back from a week away.
Old Apr 10, 2010 | 04:57 AM
veszett's Avatar
SOLVED. It was the O2 sensor, it was on its way out.
740 Turbo Brick
Oct 21, 2015 05:32 PM
DarkerStars
May 12, 2012 11:11 PM
stevolution84
Feb 21, 2012 02:26 PM
Evo1001
Feb 17, 2012 08:01 PM
vicbdn
Jul 28, 2008 09:41 PM
