Throttle stick
Old Mar 29, 2010 | 06:20 AM
skold's Avatar
Throttle stick
dunno if this should be in here but i have noticed since my last reflash i have been havent throttle stick at higher rpms i was logging today coming to work and diia 4th gear pull and when i let off it stuck at 3k?
Old Mar 29, 2010 | 07:07 AM
And's Avatar
And
that will be the settings in the rpm addr section near the bottom,
Old Mar 29, 2010 | 07:18 AM
skold's Avatar
I changed the disired boost loads to 16 scale didnt touch the address
Old Mar 29, 2010 | 07:38 AM
And's Avatar
And
i was on about the ISCV Control tables as the RPM adder's can cause the throttle to hang, these are %'s most change to 0's to stop the hang
Old Mar 29, 2010 | 08:18 AM
skold's Avatar
So do i change the desired iscv intial step positions or idle stepper motor look up table?
Old Mar 29, 2010 | 08:21 AM
And's Avatar
And
is this the only change since noticing the rev hang?
guess I should find out which rom and xml are you using?
Andy
Old Mar 29, 2010 | 12:25 PM
skold's Avatar
Rom 96420008
Old Mar 29, 2010 | 12:26 PM
skold's Avatar
And this isnt the first reflash i have ever done.so im kinda puzzled
Old Mar 30, 2010 | 12:51 AM
And's Avatar
And
have you tried reverting back to a previous rom to see if the problem is still there? and then doing a diff on them
05lanceralliart
Apr 2, 2009 07:01 PM
TonyG
Feb 21, 2008 09:49 PM
crcain
10
Nov 16, 2007 12:49 PM
Bosshog
18
Jun 19, 2007 10:58 PM
XLR8R
Jul 25, 2003 08:18 AM
