Can not read DTC's
Old Mar 31, 2010 | 12:42 PM
SinistiR's Avatar
Can not read DTC's
I am working on a 2005 Evo and can not read any DTC's or connect to the ECU for datalogging. I can flash and read the ECU with no problems. The ECU had TephraMod SD patch installed which I have removed and loaded a standard map to the ECU. The rest of the wiring has been converted back to MAF from SD. I am trying to connect to datalog and check DTC's, but I cant connect with any standard scanners or DeltaDash. I have tried an untouched 0011 ROM, a JDM map sensor pactched ROM and nothing makes a difference. The DLC is wired correctly. Anyone have any ideas?
Old Apr 1, 2010 | 05:54 PM
dunk186's Avatar
bump
Old Apr 3, 2010 | 12:32 PM
dunk186's Avatar
bump for
Old Apr 3, 2010 | 12:51 PM
todd6027's Avatar
what do you have for ecu periphery 2 fca bits , bit0
Old Apr 7, 2010 | 10:00 AM
SinistiR's Avatar
I will check that and let you know.
Old Apr 7, 2010 | 10:20 AM
SinistiR's Avatar
That bit is 0.
Old Apr 7, 2010 | 06:02 PM
iTune's Avatar
Originally Posted by SinistiR
That bit is 0.
I believe this should be set to "1".
