is my load to high?
Old Apr 6, 2010 | 12:19 PM
accident's Avatar
is my load to high?
ever since I got my current evo my load has been logging higher then my last evo.
I'm running about 27-28psi on e85 on stock 8 turbo. I sometimes see loads peak at 330-340 and taper to about 240-230 on a third gear pull.
I did a boost leak test and there are no leaks. I'm running the stock intake with a drop in BMC filter w/stock maf settings. my fuel trims are pretty decent aswell. other then the high loads the car seems fine and pulls strong. I just think my loads are kind of high compared to others with bigger setups. is there anything else to check or should I just not worry about it?
thanks,
ed
Old Apr 6, 2010 | 12:45 PM
andrewzaragoza's Avatar
are you running the same intake as well? different intakes will skew the MAF readings a bit. nothing to worry about as long as you dont have a boost leak and you are tuned on those loads.
Old Apr 7, 2010 | 06:05 AM
raasfaas's Avatar
^+1...was your last evo on the same stock intake? If not then that might be why. I saw a difference in load readings when I switched from the stock rubber intake to the injen hardpipe.
kapolani
Aug 8, 2020 07:34 AM
stunt2
May 25, 2012 01:46 PM
EVIL_EV0
Aug 20, 2008 09:32 AM
sponners
Jun 8, 2008 08:48 PM
Dapper Dan
Mar 8, 2007 08:32 PM
