Hey guys is my o2 going bad??
Old Apr 11, 2010 | 01:20 PM
ant_turbo's Avatar
My car seems like its eating more gas!! and the other day the SES light came on..
Here's a evoscan log...quick vid,,, Thanks ..
http://www.youtube.com/watch?v=NRmSMmS8ccI
Old Apr 11, 2010 | 01:35 PM
lan_evo_mr9's Avatar
what fault did you have?
Old Apr 11, 2010 | 03:21 PM
tscompusa2's Avatar
looks like its working to me
Old Apr 11, 2010 | 03:43 PM
ant_turbo's Avatar
So it is ok that it goes from a 0 reading then back to reading..
Old Apr 11, 2010 | 03:47 PM
tscompusa2's Avatar
well that i didnt even notice. I dont know. did you try unhooking the harness and reconnecting it? maybe its something stupid and as simple as that to fix. thats the front o2 at your o2 housing. what are your fuel trims?
Old Apr 11, 2010 | 03:54 PM
ant_turbo's Avatar
What should my fuel trims looks like if i have a bad front o2
Old Apr 11, 2010 | 05:41 PM
tscompusa2's Avatar
they should be within -+5%...... id imagine if the front o2 was jammed or screwed up the trims will be way off considering the front o2 is what determines the fuel trims.
Old Apr 11, 2010 | 07:04 PM
ant_turbo's Avatar
So check them at idel,,, or driving around...
Thanks......
Old Apr 11, 2010 | 07:40 PM
TurboTim06's Avatar
No your O2 Sensor should not go to 0 and then begin reading again it should bounce back and fourth from a high number to a low number depending on rich/lean A/F Ratios but not 0...higher voltage readings means a rich A/F mixture so a good diagnostic tip for an O2 Sensor is to shoot some propane into the intake while observing your O2 voltage..it should read high almost immediately....if not then you need a new O2...BTW what code did u set?
Old Apr 11, 2010 | 07:44 PM
ant_turbo's Avatar
p0420... This happend after I added 91 octane to a almost empty tank of
e85////
Old Apr 11, 2010 | 07:51 PM
TurboTim06's Avatar
Originally Posted by ant_turbo
p0420...
ohhhh ok yea you have a bad catalytic converter...i had the same thing happen to me about a year ago thats when i decided to eliminate the problem and go with a test pipe haha
Old Apr 11, 2010 | 07:53 PM
ant_turbo's Avatar
Im catless,,,,,, I have a test pipe....
Old Apr 11, 2010 | 07:59 PM
TurboTim06's Avatar
yea thats what i was figuring after i posted that post haha...if i were you i would try the propane trick and see if your O2 readings go high...its possible that your O2 is in the early stages of going bad but not bad enough to set a P0134 code for no activity detected yet
Old Apr 11, 2010 | 08:18 PM
ant_turbo's Avatar
I replaced the front o2 about 2 years ago with a bosch universal o2 sensor...
When running c16 funked it up...
RallySport Direct
Evo 'For Sale' Engine Internals and Drivetrain
180
Jan 21, 2015 09:35 AM
RallySport Direct
EvoX 'For Sale' Engine Internals and Drivetrain
173
Jan 19, 2015 10:49 AM
maperformance
Apr 20, 2009 06:51 AM
mitsuboost30
Northeast Region
11
Apr 9, 2008 07:24 PM
