Help on how-to: Log AFR from the AEM UEGO w/o a serial cable
Old May 11, 2010 | 02:52 AM
jdmevo123's Avatar
am i right calling MUT 3c as 8409? I have a JDM evo8, same pinout as the nine.
Old May 11, 2010 | 03:36 PM
jdmevo123's Avatar
Tephra or anyone, should I be using MUT3C with 0x8409 or MUT12 with 0x8409?
Currently I am using MUT3C and I cannot get the Rear 02 SIM to read my wideband signal.
Old May 11, 2010 | 08:32 PM
jdmevo123's Avatar
come on guys, one of the gurus has to know if I am calling the correct Mut address?
Just an FYI I have the 9 pinout confiuration
Old May 11, 2010 | 10:34 PM
Drill_Sergeant's Avatar
Veteran: Army
have you tried both? on my ECU im using MUT12
Old May 11, 2010 | 10:35 PM
jdmevo123's Avatar
no I havnt because i want to make sure I wont damage anything first
Old May 12, 2010 | 02:05 PM
tscompusa2's Avatar
you ever gonna get this thing ready for me dale? lol............
Old May 12, 2010 | 02:22 PM
jdmevo123's Avatar
Lol, I'm trying, as you can c I just keep running into problems. I tried mut 12 as well and it's the same just a constant 9.8
Old May 12, 2010 | 02:41 PM
tscompusa2's Avatar
Ah, well i never did it the way you're doing it so i cant help. Why dont you just run it through a serial port? its pretty easy to do.
Old May 12, 2010 | 07:02 PM
jdmevo123's Avatar
I use to run it through serial but I wanted to tidy up all the cables as it always looked like I had wires hanging out lol.
Old May 12, 2010 | 07:08 PM
tscompusa2's Avatar
i run mine into my glove box.
Old May 12, 2010 | 07:43 PM
jdmevo123's Avatar
yeah but then I still need to plug a second cable into my laptop with the other usb going across the car to the OBD port.
I guess Im just really fussy lol, plus I would like to implemement once I finally having a working tune the AFR safety threshold ect.
Old May 12, 2010 | 08:04 PM
jdmevo123's Avatar
Guys,
Quick question to use this must "Rear 02 Heater Path" in tephra V7 be 0x4A0B or must it be disabled with 0x0009.
Old May 13, 2010 | 09:06 PM
jdmevo123's Avatar
Anyone got advice on how to fix this problem? Tephra?
Old Oct 6, 2010 | 07:54 AM
Danieln's Avatar
Did you fix this issue?
I need to install also an aem uego on a JDM Evo 9 without rear O2 sensor without using a tephra rom.
I don`t believe ...this will work without a tephra rom patch.
Since JDM versions don`t use a rear O2 sensor that input in the ECU is disabled.
Still I need to look more about this issue and how to finally make it working.
Old Oct 18, 2010 | 04:09 AM
VGergo's Avatar
how to calculate the eval like this 0.03137*x+10.0 to logging by evoscan if you know your wideband volt - afr correlate ?
