Help ASAP please read
Old Apr 15, 2010 | 02:04 AM
widge's Avatar
Hey Guys,
I just got my car back from Mitsubishi today to fix the Fan Controller and IACV and i just wanted to check my current tune is on the car,
I went to flash my current rom and i got an error, i then tried to log the car with Evoscan and im getting the following message
Less then 5v detected on the cable
HELP please, thanks in advance
Old Apr 15, 2010 | 02:08 AM
dolphin888's Avatar
Is your battery well charged?
Old Apr 15, 2010 | 02:11 AM
widge's Avatar
Well it just came back from a 1.5 hr trip from syd, i dont have any lights on stereo on and the car starts perfectly
Old Apr 15, 2010 | 03:32 AM
widge's Avatar
Still need help guys i tried doing it with a battery charger plugged in to no avail
Old Apr 15, 2010 | 03:44 PM
widge's Avatar
So know one has experienced this issue before?
Old Apr 15, 2010 | 03:57 PM
LGshow19's Avatar
check your fuses...
Old Apr 15, 2010 | 04:20 PM
widge's Avatar
Ah ok because i did notice that when mitsu worked on the car they didnt remove the battery, which fuses should i be looking at under bonnet or in the car?
Old Apr 15, 2010 | 04:58 PM
EV0L-IX-MR's Avatar
I would start under the hood with the relays.
Old Apr 15, 2010 | 05:18 PM
hediki12's Avatar
yea no interior lights usually means fuse.. dsms get there obd power from the interior lights..,
Old Apr 15, 2010 | 05:35 PM
widge's Avatar
My interior lights are working, ive just noticed something else i cant lock or unlock the car with my key anymore either, i called mitsu and they told me they cannot be held responsible WTF!!!!
Going to check out fuses and stuff now, how do i tell if relays are faulty?
Old Apr 15, 2010 | 07:10 PM
LGshow19's Avatar
the U or S shape the fuse makes wont be connected.
if all your fuses are good reset your battery and makesure the terminals are good.
Old Apr 15, 2010 | 11:22 PM
EV0L-IX-MR's Avatar
relays are a little harder to test, but im an electrician and in this case no where near you to help. but you going to need a multi meeter or something with in those lines that can read ohmic values or make a beeping noise when you connect each terminal to both sides of the fuse. How ever for your relays its a little harder they have a normally closed and a normally open side. so when you test it with the multi meeter two terminals should always show a value close to zero or a beep. and the normaly open shouldnt do anything until the relay is engergized on the which you can pull of by using a battery and a couple of wires. or find out which relay is what and have a friend help you by hitting the switches to turn them on (eg. fog lights) it should make a clicking noise when it changes state.
Old Apr 16, 2010 | 12:30 AM
widge's Avatar
Fixed guys, i couldnt lock the car either but i could unlock, i looked through all fuses and one was blown, problem resolved thanks for you help
Old Apr 16, 2010 | 07:51 AM
LGshow19's Avatar
Easy fix...
