Starting to Tune!
Old May 15, 2010 | 02:18 PM
5LEEPERISAH23I's Avatar
Starting to Tune!
Well im about to start tuning my car!
What i have:
-EcuFlash
-Evoscan
-Tatrix Cable
What i Need:
I need something to read WB02.. I want to get somthing where i can share the WB02 Sensor between me and my brothers evo...
I would like the get the LC-1 ... is that good? "I dont want something were i can use it in my brothers car also"
Where do i hook the LC-1 Too? not the OBDII bec that is where tractix cable would be hooked up to the labtop. so what would i hook up the LC-1 Too?
thanks guy!
Old May 15, 2010 | 05:06 PM
evo8426's Avatar
i have the lc-1 and it is very simple to install and remove from the car. the first one i had was buggy but since i got a new one i did a lot better soldering the wires and it has worked flawlessly since day one. would definitely recommend the lc-1
Old May 15, 2010 | 05:09 PM
3gEclipseTurbo's Avatar
I would never share a wideband as you always want it in your car to spot a problem like going lean in boost before you blow up your engine. Say one of you injectors gets clogged wouldnt you like to know that the enginge isnt getting enough fuel? I would.
Old May 15, 2010 | 05:37 PM
Tribal's Avatar
Also make sure to read merlin's guide on tuning very helpful tool.
Old May 15, 2010 | 05:40 PM
Macaroni's Avatar
Tons of information on here to use to your advantage. Soak it all in and good luck tuning! +1 on the LC-1
Old May 15, 2010 | 06:15 PM
evo8426's Avatar
I have never had the gauge in the car, there are more important things to worry about when going WOT than looking at a gauge. There are animals, children, or people that could appear in the road and you would not see them because your eyes are focused elsewhere. I use evoscan to log my a/f and boost so I know what is going on and have Tephra's v7 rom set to flash CEL and drop boost if there is a problem.
Old May 15, 2010 | 08:14 PM
hellcat's Avatar
Take your time and make small adjustments at first and make sure to pay super close attention to the effects.
Old May 15, 2010 | 08:38 PM
with the LC-1.. u install the software to ur computer and when u data log the car on evoscan it reads ur data on logworks?
Old May 15, 2010 | 09:23 PM
I have never seen any animals, children, or people on the track when i pulled up to the tree. I dont know what the tracks like where you live but i wouldnt go there if i had to watch out for animals, children, or people jumping out onto the track while i was in the middle of a run.
Old May 15, 2010 | 11:20 PM
evo8426's Avatar
Well I meant as a DD for spirited runs checking on the car or for autocross, there are no tracks near me other than the occasional autocross in local parking lots.
Old May 16, 2010 | 12:48 PM
kreionic's Avatar
you can log to either log works or evoscan. One or the other. Either log with evoscan and set it up to log with evoscan using a serial cable or hard wire the lc1 to the ecu. Or log with logworks. Logworks will log through the open port cable
Old May 16, 2010 | 06:21 PM
how do i make the lc-1 log to evoscan? u say using a serial cable? were do i get that?
Old May 16, 2010 | 06:32 PM
kreionic's Avatar
the lc1 comes with a serial cable. Thats how the wideband and computer communicate. You set up the wideband, calibrate it etc.. using serial cable and lm programmer. It plugs in the out of the lc1. If your laptop doesnt have a serial port use a serial to usb adapter. Any electronic store has them. Plug it in the laptop in evoscan select lc1 set the com port and your good to go.
Old May 17, 2010 | 04:19 PM
does the usb adapter come with the LC-1? or do i need to buy the adaptor?
so ill i do it buy the LC-1, connect the serial cable to my computer, get the WB02 in the exhuast, n on evoscan select LC-1..
i do need to hook it up to a ground, a batterary, or anything like that?
Old May 17, 2010 | 06:06 PM
philr8's Avatar
you will need to buy a serial to usb adaptor
LC1 install
- 12v power
- Ground (good ground at that)
- Analog out to ecu if you want! Or log via serial
- Weld bung into end of down pipe or decat pipe
Very easy to install!
Phil
