Injectors help
Old May 27, 2010 | 11:39 AM
tigerkill2007's Avatar
Injectors help
Well I just installed some pte 1200cc injectors in the evo and I would like to start rescaling the injectors but i have a problem...any help would be nice...i am still a noob at rescaling injectors...I use to have some 880cc injectors scaled at 713...
First question is why can't i increment my injector scaling past 770..and how do i make it increment past 770
Not a question but what have most pte 1200cc injector been scaled at and what are the latency...would just like to have a good starting point
and also do i need my o2 sensor connected and working for me to log stft and ltft...
Old May 27, 2010 | 11:45 AM
evodood's Avatar
You can increase your scaling beyond 770 the ecu only accepts certain values though so if your not going high enough to get to the next value it will continue to round down to 770.
Old May 27, 2010 | 11:48 AM
When I open the injector scaling window and start to increment it up it will stop at 770...what do I need to do to go past that...
Old May 27, 2010 | 12:24 PM
travman's Avatar
start manually typing in numbers.......like 790 / 812 / 835 / etc etc It will land you to the closest value and then go from there
There should be someone on here who can give u a solid scaling to start from so your not going increment by increment.......or search I am sure someone posted scalings for pte1200's to give u a good start.
Old May 27, 2010 | 12:51 PM
evodood's Avatar
I'm sure the scaling and latency values for PTE 1200s are in the big Injector Scaling thread on here. It would supprise me that in like 50+ pages of injector data they weren't
