Load only showing one value?
I set up Load 2bit on the ecuflash and evoscan but when i do a log, the load value only shows as 2741.875. Its always 2741.875 at every RPM and even at idle. Is there something wrong that I'm not doing right?
thanks for the help
thanks for the help
I made the same mistake when I was setting up 2byte load. Like RoadSpike said, you need to setup your mut addresses correctly. You'll need to find what addresses you need to enter into the MUT00 and MUT01 tables depending on what ROM version you have in this thread :
https://www.evolutionm.net/forums/ec...te-thread.html
Then enter the corresponding values into your own map, and flash it to your car. For example, my rom version is 88590015. My MUT00 value is 6B42 (entered as 0x6B42 in Ecuflash) and my MUT01 value is 6B43 (again, entered as 0x6B43 in Ecuflash).
After that make sure that in Evoscan your 2byteload is looking at requestid 00 and requestid 01, which correspond to MUT00 and MUT01.
Hope that helps, if not let me know and I'll try to explain better :P
