Airtrek XML definition wanted
Old Aug 23, 2021 | 03:07 AM
  #31
ifti's Avatar
Yes i have totally removed the solenoids i.e (EGR, FPR, boost) and all the vacuum pipes.
Made a block of plate for EGR and the fuel pressure regulator vacuum line goes to is directly intake.
So should I plug all those solenoids back?
Old Aug 23, 2021 | 03:08 AM
  #32
ifti's Avatar
Originally Posted by nikush
Try.
Thanks.
I have downloaded the file you sent me but still same error.
I have removed all the hardwire meaning ERG, boost and FPR solenoids and their wires are not connected to anything
Old Aug 23, 2021 | 03:10 AM
  #33
ifti's Avatar
Originally Posted by OzAirtrek
That file originally has the EGR bit enabled-just the EGR tables are zeroed out. If you change the bit to turn off the EGR totally (which you have in your file) you will get a check engine light. Is your EGR hardware removed? because i dont think you can get around it - which i why in the original file the bit is still set at 1
Old Aug 23, 2021 | 03:38 PM
  #34
OzAirtrek's Avatar
I don't know the solution then. To my knowledge you can't turn off the EGR - you will get the check engine light.
Old Aug 23, 2021 | 04:05 PM
  #35
ifti's Avatar
Ok no worries. I will just plug the solenoid back and see what it does
Old Aug 24, 2021 | 05:45 PM
  #36
ifti's Avatar
I did plugged the EGR solenoid back and left the EGR enable bit on ECU as 1. The check light went away.
Thanks a lot
Old Aug 25, 2021 | 06:42 AM
  #37
sikest's Avatar
Thanks a lot
I have all the erg stuff out and it was turn off. No check engine light so may depend on how advance your xml file is. There are persons selling updated roms and xml files.
Old Oct 4, 2021 | 02:44 AM
  #38
ifti's Avatar
Can you help me with the ROM and XML files? I am also having issues with reading correct load valves into evo scan. The max it goes to is 100%
Old Oct 4, 2021 | 02:50 AM
  #39
Dow Jhob's Avatar
you need two byte load
Old Oct 4, 2021 | 02:51 AM
  #40
OzAirtrek's Avatar
Bottom of the first post has everything you need. Make sure you are using newest version of ecuflash. Once you flash this rom use the 2 byte load in evoscan
Old Oct 4, 2021 | 03:20 PM
  #41
ifti's Avatar
Hey thanks,
My fault. When I was using EvoScan, the OBD2 96-05 was ticked instead of Mitsubishi MUTIII.
All working now. Time to send it
limaynard
Aug 9, 2024 06:29 AM
jarjar1977
May 9, 2016 01:40 AM
airtrek365
Jan 11, 2016 01:50 AM
SX200
Dec 30, 2015 01:56 AM
koolkiwikat
May 26, 2007 03:12 AM
