tables not showing in ecuflash
Old Jul 8, 2010 | 02:11 PM
bevolucion's Avatar
well I very frustrated at this point, I have tried to add tables in this case to pass the inspection test. I have used notepad to add the definitions to ecuflash, I have done this with other tables succesfully. Well I stand here, if right now I open the xml file 94170015 through notepad which is mine it shows that all the definitions are there, including the ones for emission non-continuous... patch 1,..patch 2 etc.(recompile thread) tables don't show in ecu falsh . But if the same file I open through XML editor it only shows the definitions for the tables that show in ecuflash not the emission ones, which makes sense. Like I said I have altered my ecuflash before with notepad with success I have not a clue why I can't now. If any body can help me I would greatly appreciated.
BTW I need this to pass inspection asap do to:
-Catalyst Monitor Not ready
-O2 Sensor monitor Not Ready
-O2 Sensor heater monitor Not Ready
Old Jul 8, 2010 | 04:11 PM
Booztd 3's Avatar
Care to post up the XML?
If not PM me and i'll give you my email addy and I'll take a look....
Old Jul 8, 2010 | 04:35 PM
Evoryder's Avatar
Are you in developer mode? Are you adding it to a modded 94170015? If so it may have to be split half the info in the xml and the other half in evo 7 base. Pay close attention to the format and also where you're pasting the info.
Old Jul 8, 2010 | 07:24 PM
bevolucion's Avatar
kind of lost me on this one, yes everything is under developer I don't understand about spliting the info.
worst come the worst I am ganna have to hunt down Recompile through out Mass
Old Jul 8, 2010 | 08:12 PM
Evoryder's Avatar
Please Email someone your rom.
Old Jul 8, 2010 | 08:20 PM
Appauldd's Avatar
If you are writing XML you should understand that there is a base and a rom specific XML. They are a pair and must work together.
I recommend removing whatever XML you wrote and re-install some that is "stock". Then you can use them as the basis for your writing. Sometimes we have to take a step back to make 2 steps forward.
Old Jul 9, 2010 | 08:56 AM
bevolucion's Avatar
<rom>
<romid>
<xmlid>94170015</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>94170015</internalidhex>
<caseid>MN132874</caseid>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2004</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
<table name="High Octane Fuel Map" address="33bd">
<table name="Load" address="6694" elements="18"/>
<table name="RPM" address="666c" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="34d7">
</table>
<table name="High Octane Ignition Map 1" address="39d5">
<table name="Load" address="66f4" elements="19"/>
<table name="RPM" address="66c2" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3b5d">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="37c0">
<table name="Battery Voltage" address="65d4" elements="7"/>
</table>
<table name="Rev Limit" address="158c"/>
<table name="Stationary Rev Limit" address="2b4a"/>
<table name="Accel Enrichment" address="3864">
<table name="RPM" address="6406" elements="15"/>
</table>
<table name="Boost Control Load Offset" address="1a70"/>
<table name="Turbo Boost Error Correction" address="4488">
<table name="Boost Error" address="69ac" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="44f8">
<table name="RPM" address="6982" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="450e">
</table>
<table name="Boost Desired Engine Load # 3" address="4524">
</table>
<table name="Boost Desired Engine Load # 4" address="453a">
</table>
<table name="Max Wastegate Duty # 1" address="44a0">
</table>
<table name="Max Wastegate Duty # 2" address="44b6">
</table>
<table name="Max Wastegate Duty # 3" address="44cc">
</table>
<table name="Max Wastegate Duty # 4" address="44e2">
<table name="RPM" address="6982"/>
</table>
<table name="Open Loop Load # 1" address="3624">
<table name="RPM" address="6378" elements="15"/>
</table>
<table name="Open Loop Load # 2" address="363a">
</table>
<table name="Open Loop Throttle Low Load" address="3656">
</table>
<table name="Open Loop Throttle High Load" address="366c">
</table>
<table name="IC Relay Timer Time" address="2498">
<table name="Condition"/>
</table>
<table name="IC Relay Timer Control Judgement" address="209e">
</table>
<table name="IC Relay Timer Air Temp" address="20a2"/>
<table name="IC Relay Timer ON Mode Switch Time" address="247e"/>
<table name="IC Relay Timer Control RPM" address="2480"/>
<table name="IC Relay Timer Control Water Temp" address="2482">
</table>
<table name="IC Relay Control Vehicle Speed" address="2486"/>
<table name="IC Relay Control EV" address="2488"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="4276">
<table name="Engine Temp" address="68b8" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="4284">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="4292">
</table>
<table name="Desired Idle RPM-Neutral" address="425a">
</table>
<table name="Desired Idle RPM-Drive" address="4268">
</table>
<table name="High Intake Air Temp ISCV Increase" address="220e">
<table name="Condition" elements="2"/>
</table>
<table name="Boost Limit" address="3614">
<table name="RPM" address="6b7e" elements="9"/>
</table>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1680"/>
<table name="Desired Idle RPM with AC on" address="186c">
</table>
<table name="High Intake Air Temp Idle Speed Target" address="220a">
</table>
<table name="Wastgate Solenoid Activation RPM" address="1668">
</table>
<table name="Speed Limit" address="158e">
</table>
<table name="Injector Scaling" address="1506"/>
<table name="Min Coolant Temp for Closed Loop" address="15aa"/>
<table name="Boost Cut Delay Timer" address="159a"/>
<table name="MAF Scaling" address="3306" scaling="AirFlow8">
<table name="Load" address="6584" elements="21"/>
</table>
<table name="MAF Smoothing Table" address="3322">
</table>
<table name="Air Temperature Compensation" address="333e" scaling="uint8">
<table name="Degrees" address="68b8" elements="8"/>
</table>
<table name="Barometric Pressure Compensation" address="3351">
<table name="Atmosphere Pressure" address="6572" elements="4"/>
<table name="RPM" address="65b8" elements="9"/>
</table>
<table name="Idle Stepper Look-up Table" address="4399">
<table name="Throttle Position" address="68b8" elements="8"/>
<table name="RPM" address="68d2" elements="27"/>
</table>
<table name="Knock Sensor Filter Map 1" address="485b" level="4">
<table name="TAR" address="6a8a" elements="12"/>
<table name="RPM" address="6a6a" elements="11"/>
</table>
<table name="Knock Sensor Filter Map 2" address="48eb">
</table>
<table name="Knock Sensor Filter Map 3" address="497b">
</table>
<table name="Knock Sensor Filter Map 4" address="4a0b">
</table>
<table name="Knock Sensor Filter Map 5" address="4a9b">
</table>
<table name="Knock Sensor Filter Map 6" address="4b2b">
</table>
<table name="Knock Sensor Filter Map 7" address="4e09">
</table>
<table name="Knock Sensor Filter Map 8" address="4e99">
</table>
<table name="Knock Sensor Filter Map 9" address="4f29">
</table>
<table name="Knock Sensor Filter Map 10" address="4fb9">
</table>
<table name="Knock Sensor Filter Map 11" address="5049">
</table>
<table name="Knock Sensor Filter Map 12" address="50d9">
</table>
<table name="MAF Sensor Filtering" address="1508">
<table name="Load"/>
</table>
<table name="MAF Size" address="150c"/>
<table name="Min Temp for Full Boost Control" address="2200"/>
<table name="Boost Control Limiting Vehicle Speed" address="2204">
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1682" level="3"/>
<table name="Boost Enhancement (Anti-lag) Table" address="39b6">
<table name="RPM" address="6654"/>
</table>
<table name="Wastegate Compensation" address="4478"/>
<table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" address="3ce5">
<table name="Load" address="66f4"/>
<table name="RPM" address="66c2"/>
</table>
<table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" address="3e6d">
<table name="Load" address="66f4" scaling="Load"/>
<table name="RPM" address="66c2" scaling="RPM"/>
</table>
<table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" address="3ff5">
</table>
<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="36872" type="1D" level="1" scaling="Hex16"/>
<table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="36888" type="1D" level="1" scaling="Hex16"/>
<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="3688E" type="2D" level="1" scaling="Hex16">
<table type="Static Y Axis" elements="2">
<data>3688E</data>
<data>36890</data>
</table>
</table>
<table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="36889" type="2D" level="2" scaling="blobbits">
<table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
<data>EGR system</data>
<data>Oxygen heater sensor</data>
<data>Oxygen sensor</data>
<data>A/C system refrigerant</data>
<data>Secondary air system</data>
<data>Evaporative system</data>
<data>Heated catalyst</data>
<data>Catalyst</data>
</table>
</table>
<table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="3688F" type="2D" level="2" scaling="blobbits">
<table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
</table>
</table>
</rom>
Old Jul 9, 2010 | 08:58 AM
bevolucion's Avatar
this is my rom as seen it shows all the tables. BTW I really appreciate every ones help.
This is through NOTEPAD
Thanks.
Old Jul 9, 2010 | 09:57 AM
Appauldd's Avatar
You have an old version. Shoot me an email at the same screen name at g mail. I will send you an updated xml set that will allow you to see all of the tables available for 94170015.
I recommend going to Tephra v5.10 94170015 as the knock light feature is wonderful. My XML will show all of the tephra tables too.
Then as you continue to learn, switch to v7 and let your brain explode from information overload.
Paul
Old Jul 9, 2010 | 10:15 AM
bevolucion's Avatar
i will give it a shot
Old Jul 9, 2010 | 10:18 AM
bevolucion's Avatar
Paul
i just emailed you
Old Jul 9, 2010 | 10:21 AM
bevolucion's Avatar
yeah i have read about tephras definitions, it is unbeliveable definetely blows my mind
Old Jul 9, 2010 | 10:30 AM
Evoryder's Avatar
Appauld got you
Old Jul 9, 2010 | 11:18 AM
Appauldd's Avatar
Yeah....Jeff I am all over this one.
It seems there is still a few of us in here that like to help others.
Old Jul 9, 2010 | 12:39 PM
bevolucion's Avatar
thanks i got the info but when I open 94170015v5 in Ecuflash I still get the same tables as before nothing new. What the hell is going on with my ecu flash program?!!! I already pasted everithing else in notepad for the xml files. just not working
