Needs the help. EcuFlash reads but does not write
Old Jul 12, 2010 | 03:08 AM
Tomcat's Avatar
Machine Lancer 9 2003, 4G18 1.6L, cable OP1.3 ECU SH7052
EcuFlash 1.29a.
The ROM 93270014 (was read -was written after editing in EcuEdit, EcuFlash well).
Has Afterwards written 93270019 (with updated Lancer 9 2006) (reading - an editing-record well).
The Voltage on battery 12,4-12,6 volt. (EcuEdit logger).
In ROM 93270019 EcuFlash reads, without editing, that writes in test mode - well.
But with editing in EcuFlash or in EcuEdit, record in test mode is broken on 50%. Mostly, the block CRC shows YES, but on three NO (operates protection? ). In an effort lace trims in usual mode gives redden mistake and record does not go. The Engine is wound, ECU works.
What release ECU on record ? Possible that EcuEdit and EcuFlash at editings spoil the lace trim (CRC control totals do not coincide)? Or problem can be in cable OP1.3 ? (what check additional releasing cable? 4.42-4.46 volt)
Beside who such was? What have solved a problem ?
Who else can prompt on table MUT for reading in 2 byte LOAD RPM and AFR ?
MUT 00 01
02 03
04 05
File Type: zip
