JDM E7 99860002 to 90550001 v5.10
@ shifty180: sure, im not at home but i'll post them as soon as i can
check out this thread, on pag 4 are the code lines for several ROMs, courtesy of Deepnine
https://www.evolutionm.net/forums/ec...ditions-4.html
yap thats right burges22, my bad...
Thermo Fan Dutys
for 90550001 @xml file (just copy/past)
<table name="Thermo Fan Duty" category="Misc" address="43d2" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Thermo Fan Duty #2" category="Misc" address="4c48" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="3">
<data>On</data>
<data>Off</data>
<data>A/C</data>
</table>
for 99860002
<table name="Thermo Fan Duty 0-22kph" category="Fan control" address="5276" type="3D" swapxy="true" scaling="Percent (128)">
<data>Main Fan 0-22kph</data>
<data>A/C Fan 0-22kph</data>
<data>Main+A/C 0-22kph</data>
</table>
<table name="Thermo Fan Duty 22-52-82kph" category="Fan control" address="43d2" type="3D" swapxy="true" scaling="Percent (128)">
<data>Main Fan 20-50kph</data>
<data>Main Fan 50-80kph</data>
<data>Main Fan 80->>kph</data>
<data>A/C Fan 20-50kph</data>
<data>A/C Fan 50-80kph</data>
<data>A/C Fan 80->>kph</data>
<data>Main+A/C 20-50kph</data>
<data>Main+A/C 50-80kph</data>
<data>Main+A/C 80->>kph</data>
</table>
Thermo Fan Dutys
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<data>On</data>
<data>Off</data>
<data>A/C</data>
</table>
for 99860002
</table>
</table>
thanks for the code.
Cant seem to get the tables to show up.
I did add some </table> tags as the code seems incomplete. But yeah, the tables dont show up on ecuflash.
Make sure you delete all other XML's under the "rommetadata" folder, or sub folders mate, as it will reference any others that are available and won't show changes.
I had the same issues, there was two </table> tags missing, however the table is greyed out, and I can't read the rom, perhaps i have to download it now that i have the updated XML?
<table name="Thermo Fan Duty" category="Fan Setting" address="43d2" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="513e" type="Y Axis" elements="12" scaling="Temp"/>
</table>
<table name="Thermo Fan Duty #2" category="Fan Setting" address="4c48" type="3D" level="1" swapxy="true" scaling="Percent (128)">
<data>On</data>
<data>Off</data>
<data>A/C</data>
</table>
</table>
that's the complete code and below is the scaling you will need to add too.
<scaling name="Percent (128)" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
</table>
<data>On</data>
<data>Off</data>
<data>A/C</data>
</table>
</table>
Bingo!
Was missing the scaling.
Cheers lads.
Since 90550001 is an RA based map, it appears its setup for a low-temp Ralliart thermostat that opens mid 70*C from memory.
I'll check a few factory non RA JDM maps, and see what they are set up as.
Heres how mine is... any comments?
Was missing the scaling.Cheers lads.
glad you sort them out!!
Bingo!
Cheers lads.
your table is like mine...err was like mine.
yes there is a RALLIART thermostat, lower opening temp to standard.
The link below shows the unit, you should be able to get it.
http://www.meek.com.au/index.php?act...d&productId=94
"moving": i can not hear the fans working, so half the problem solved.
have to push the engine and log it...
i have a log i did yesterday: stationary and moving a little, but i cant upload it...not even with rar...any ideas?
Its .csv log yeah?
I'm trying to understand the relationship between the Thermo duty table #1 and #2!
Damn variable fan, why can't it just be like Autronic, "ON" temp and "off" temp.
Edit: reading it now in Merlins... this guy has covered everything!
