cant log 2 byte load using 4013
Old Jul 30, 2010 | 07:42 AM
adcgn45's Avatar
anyone have the addresses to log 2 byte load for 9694013? ive tried 4011 and they dont work
Old Jul 30, 2010 | 09:09 AM
adcgn45's Avatar
well this is discouraging.
Old Jul 30, 2010 | 09:21 AM
RoadSpike's Avatar
Unless you're willing to disassemble that rom you'd be better off switching to a more supported one.
Old Jul 30, 2010 | 09:35 AM
adcgn45's Avatar
well i wanted to use tephra v7 but not 9653 and thats the only one out for my car. i tried ity and had nothing but idle problems.
which rom do you suggest? 05 evo 8
Old Jul 30, 2010 | 09:54 AM
RoadSpike's Avatar
You could try the 9417 variant of the tephra patch.
I'm surprised you had idle problems with it though.
Old Jul 30, 2010 | 10:56 AM
adcgn45's Avatar
ok so i trashed the 4013 and decided to bite the bullet and screw around with 9653 v7 and get the idle right. so far so good.. except it wont log the 1 or 2 byte load either.
Old Jul 30, 2010 | 10:59 AM
RoadSpike's Avatar
v7 isn't setup to log 2byte load just log the 1byte load instead if you have evoscan it should be built in i think. If not search a bit and you can find the xml needed to log it.
Old Jul 30, 2010 | 11:00 AM
adcgn45's Avatar
ahh ok nvm i got it. hopefully this idle works out
Old Jul 30, 2010 | 11:03 AM
RoadSpike's Avatar
So what exactly does your idle do?
Old Jul 30, 2010 | 11:32 AM
adcgn45's Avatar
the car stalls when i turn the steering wheel sometimes. and it just seems somewhat unsmooth with occasional upps and downs. the downs can drop low enough to trigger my oil light ,like 300 rpm. never had these problems.
i just increased the values in the iscv desired rpm catagories in the higher temp ranges.
i didnt want to mess with the stepper because i dont understand it
Old Jul 30, 2010 | 11:35 AM
RoadSpike's Avatar
Then just copy your values from the stock rom to the new one if you don't understand it.
I would double check your maf compensation too i know its different than most stock evo roms.
Old Jul 30, 2010 | 11:37 AM
adcgn45's Avatar
and i got 1 byte and 2 byte to work yea! now i can finally tune more accurately
Old Jul 30, 2010 | 11:46 AM
adcgn45's Avatar
ok thanks i just checked and they were slightly different so i changed them to match
Old Jul 30, 2010 | 12:50 PM
drifterific's Avatar
How did you get 1 byte and 2 byte working? Did you have to change anything in the MUT tables. I did the mods underr the Tephra v7 thread to Evoscan and changed my 1byte load factor to 1.3 in EcuFlash to match evo scan but it still wont work with map tracer.
Im using 96530706 Tephra V7
Old Jul 30, 2010 | 12:54 PM
RoadSpike's Avatar
I just copied the formula for the 1 byte into the 2byte log portion and map tracer works with 1 byte :P
