Evoscan actuating the ABS
Old Aug 10, 2010 | 04:10 AM
CharlieN's Avatar
Has anyone been able to cycle their ABS with Evoscan?
I need to cycle the ABS system and have Evoscan 2.7 with a 1.3U cable.
I can not connect to the ABS.
The cable has pin 1 & 15 connected so the L line is complete.
Gray wire from pin 9 is removed from the car.
Drivers are from Evoflash and ES sees the cable. I presume if ES sees the cable this is not a driver issue?
The car has an Autronic ECU so I can not do other tests on this car.
The computer runs XP Pro SP2.
Could this be a faulty cable?
I can not connect to my Montero with this cable either.
