PTE Injector Scaling Opinions
im beggining to think that these injectors are bigger than a 1000. I flashed back to my old maf v7 and tried the injector settings and STFT is maxing out at 25. So I increased the latencies and that still didn't help.
the number on 2 of the injectors are 048747 and 048717 and they say precision injectors on them.
I double checked with the guy that I bought the injectors from and he verified that they are 1000's. I tried the other scaling latencies that were posted in this thread but for whatever the reason the car did not like those settings and the fuel trims were way off. I flashed back to the scalings that I posted the picture of and the fuel trims came back in line.
Another thing that I think might be messing all of this up is that the map itself is not tuned and is pretty close to the stock tephra(fuel/timing) that is packed in the tephra v7 thread.
Still using the 886 scalings I posted and short term is within 2% mid is -1% so they seem to be dialed in very well and I did adjust the scaling setting in evoscan when logging. Will i need to change these setting after other mods?
So I worked on my injector scaling today and for whatever the reason Ecu Flash will not let me input 725 for the injector scaling so I started at 731 and ended up at 713 to get my idle trims within 2%. Cruise or LTFT mid is at -6% but I will try to get that worked out tomorrow. To get my trims inline i had to change the MAF Compensation table just a bit.
I didn't want to start a whole new thread for this but it seems ever since I changed the injector scaling box in evo scan it does not want to load my rom when in maptracer. I loaded a log and rom before I changed the injector scaling and maptracer works fine, but with the new scalings it does not load the rom in the lower portion of maptracer. Any thoughts on this?
Bin not Loading in Map Tracer
So I got this figured out by searching for a few hours. I left clicked the lower portion of map tracer where it was not showing my current rom and it wouldn't load the .bin file.
So what you need to do is left click where your .bin file would normally be and click "Load HEX and XML file" and find your xml file for the rom you are using and then double click it to load it. Then you will need to load the rom(.bin) for the log you just ran.
TheBigD
Mar 3, 2013 10:14 AM
