Could this be possible w/ ICS spray on knock mod
I have been reading about the ICS spray on knock feature and i was curious it that could be incorporated to switch maps. Since you can switch maps with the ICS and you can have the ICS spray once it hits a predetermined knock setting then in theory couldnt there be a feature where if the ICS in the the auto mode and it is run to pin 42, could it then once hit a certain knock count and turns on to spray it will also signal the alt map switching and put you on a safe map? I am running the aquamist hfs-6 so i will already have a wire plugged in pin 42 where the dds3 supplies 5v to the pin until a failsafe condition activates and it then cuts power to 0v and triggers map switching. Just curious if this could be possible while using the ICS in auto if its tapped into the pin 42 wire.
