phantom or real part throttle knock (stroker)
Old Oct 11, 2010 | 12:57 PM
EvolutionEst's Avatar
Hi,
I've been trying to tune my 2.3 stroker. I've scaled the injectors and now carefully starting to tune. Up to 3000 rpm it drives very well, boosting up to 0,6 bar. But when I try to go over 3000 rpm (part throttle) it knocks at around 3500 everytime (boost still no more than 0,7 bar). I've richened the afr and pulled timing quite a lot, but nothing seems to help. So I started thinking that it may be phantom knock, but wanted to be sure, so if someone could please look at my log and confirm it, I would appreciate it very much.
Also, if someone could share his timing map for a stroker, that would help a lot.
Thanks.
File Type: zip
Old Oct 11, 2010 | 09:50 PM
dyezak's Avatar
To be quite honest, you can have people look at logs, but everyone would be taking an educated guess. You won't get a definitive answer. If you want to know, get some det-cans, or go to a shop that has some.
Old Oct 12, 2010 | 08:07 AM
I see - will have to find a place to get them.
Still can anybody share a base timing map for a stroker - I've searched, but the best advice that I found was just to pull a couple of degrees from the stock map and start from there. Any other advice?
Old Oct 12, 2010 | 05:05 PM
hediki12's Avatar
easiest way.... get some race gas and throw it in. adjust knock control till it goes away..... simple ...
2rbolag
Northeast Region
Sep 5, 2017 10:21 AM
BigEvo908
19
Apr 10, 2017 10:16 AM
4b11slayer
Nov 1, 2016 02:38 PM
axxevo8
Nov 12, 2015 11:43 AM
krillin
Feb 6, 2007 10:01 AM
