o2 trim freezing up, trims not recording...
Old Oct 22, 2010 | 12:58 PM
Jack_of_Trades's Avatar
Something is up with your STFT signal. I graphed it out since it looked like a pattern.
So its either your Front O2 sensor needs replacing or you are somehow logging the wrong item in the logger.
What REQUEST ID's do you have listed for your STFT (O2 Feedback) in Evoscan? Are you running a Tephra patch?
Old Oct 22, 2010 | 01:10 PM
05blue8's Avatar
RequestID is 0F and I've tried a second o2 sensor, no codes thrown with either, car runs the same with both. I know when I unplug the o2 the car runs like crap and also when it is disabled it runs like crap. Could it be going bad? It has a tephra mod on it, 96530706...here's a screenshot. Thanks for your help Jack...when this is resolved I'm going to send you some cash for your assistance.
Attached Thumbnails o2 trim freezing up, trims not recording...-trims.jpg   o2 trim freezing up, trims not recording...-tephra.jpg
Old Oct 22, 2010 | 01:27 PM
The next thing to check would be your MUT table in ECUFlash and see what value is listed on the chart for 0F.
Old Oct 22, 2010 | 01:28 PM
05blue8's Avatar
Here's the table...
Old Oct 22, 2010 | 01:32 PM
Well thats the correct value alright,hmm...
Old Oct 22, 2010 | 01:33 PM
05blue8's Avatar
Damn it, I was hoping for a different answer
Old Oct 22, 2010 | 01:37 PM
l2r99gst's Avatar
For a test, why don't you mometarily raise your idle RPM by a good amount. You may simply be running into the mimimum pulsewidth issues with that large of an injector.
If so, maybe do the mods to mess with the minimum pulsewidth.
Old Oct 22, 2010 | 01:38 PM
Im thinking lol. Those readings are too much of a pattern to be real so I doubt that is showing actual trim values somehow. Have you tried loading a FRESH 9653xxx6 rom of any sort just to see if its the same result? Sometimes ROM's can become corrupt,happens more often than you'd think.
Old Oct 22, 2010 | 01:48 PM
Mellon Racing's Avatar
put the oem rom back on the car and btw, which nb02 sensor brand/model did you install, some don't work.
Old Oct 22, 2010 | 01:51 PM
05blue8's Avatar
It is a stock replacement, not an off brand, the factory one.
Let me talk to my tuner and have him try that. Thanks guys, all ideas are welcome
Old Oct 22, 2010 | 02:22 PM
05blue8's Avatar
I just talked to another tuner who thinks it's the min pulsewidth issue also *sigh*
Old Oct 22, 2010 | 02:25 PM
the 05 evo has the 96940011 rom and those v7 rom's are "universal" and used on several different evo 8 models which I've never thought was a good idea.
Old Oct 22, 2010 | 02:31 PM
Are you running the stock FPR or an adjustable one? If its an adjustable one, you can try lowering the static fuel pressure to 35psi instead of the factory 43psi so you can add more IPW at idle.
Old Oct 22, 2010 | 04:46 PM
05blue8's Avatar
So another development...I swapped my omni 4 bar map sensor and rom 965 to the stock 1 bar on 0011 and it worked, all trims recorded. I did this because I looked at previous logs and my 1 bar logged trims long ago when my original 4 bar took a crap so this was a replacement. It was the only 0011 xml I had with any sort of tuning done on the 2150's. Does this indicate it is in fact not an IPW issue?
Stock FPR.
He went to that ROM for better boost control and 0011 being so limiting tuning wise.
Old Oct 25, 2010 | 02:22 PM
Stock FPR.
fwiw I run 38psi and make 705awhp on the 96940011 so don't let anyone tell you that ROM is limited it's technically a tephra v2 ROM as it lost support after that due to space limitations for teprha's mods (which I don't really need anyway).
