Injector Duty Cycle 110%??
Old Nov 15, 2010 | 10:34 PM
F0RSAKEN's Avatar
My stockers went to 116% before they couldn't richen my AFRs up anymore, so I dropped in my 880's. Now I see 76-80% IDC at 26lbs on 92oct stock turbo, 11.5 AFR @ 7000-8000.
Old Nov 15, 2010 | 11:30 PM
codgi's Avatar
Originally Posted by Boosted Tuning
I have NEVER heard, seen or read that anywhere in the ECUflash forum, and I have been here since the beginning ('06). Also, I have been using EvoScan since version .97.
Do you have a link or post for reference??
This was questioned a few years ago. Here's one easy example I could find:
https://www.evolutionm.net/forums/ec...culations.html
I don't think we ever had a true conclusion on it (or if we did, I don't remember or didn't read the thread) but clearly if the IDC being logged was truly accurate then you'd never be able to richen the AFR of a car in a controlled fashion once it got past the static threshold (which would be before 100%). And we know that you can still richen the AFR of a car into at least the early 100s....
Be interesting to see what the latest news on this is.
Old Nov 15, 2010 | 11:59 PM
widge's Avatar
Ive got the below mods @ 26psi peak but drops to like 18psi at redline and im at 96% IDC with stock injectors
350whp too so i dont understand why yours are so high
Old Nov 16, 2010 | 07:44 PM
knochgoon24's Avatar
I noticed that the formula for IDC has changed between the first post in that link and what I have now.
So something much have changed along the line.
Old Nov 17, 2010 | 12:08 AM
ZanarkO's Avatar
Eh thanks for the advice guys I plan on picking up some ID1000cc injectors friday from AWD. I just wanted to clarify my issue. So at this point Ide have to go back to my original thinking. I need bigger injectors. I was just noticing the type of power alot of these guys are making and they never mention there using anything bigger then stock injectors and it had me confused. I just thought it was next to impossible for any AWD car with 560cc injectors to be making 350-360whp (Im referring to EVO IX's with bolt ons and cams) with out a FPR.
Old Nov 17, 2010 | 12:18 AM
ZanarkO's Avatar
Originally Posted by beast666
My friends '05 with a br intake, br delux fmic, forge mbc, evo 9 bov, turbo xs 3" tbe and a walbor was running 96% idc untuned running 20si peak and 19psi red. In the 5500-7200rpm range the car went from around 10.3 to 9.8afr. After the tune the car ran 10.6 to 11.1afr in the same rpm range and the idc fell to around 92-94% according to evoscan with the boost untouched. Now in your situation you're running about a half point leaner afr's and 2-3psi more so I hope you can see what I'm attributing as the most probable factor(lower the boost). Try boosting 19psi, log it and adjust the timing accordingly...unless you want to go the bigger injectors route. With the 3 mods you have you could make 310-320whp(dynojet) on an semi agressive tune at around 20psi. Most of the the difference in the 2-3psi more with your setup is going to be more torque at peak spool and a higher egt. Just my .02 hope it steers you in the right direction.
Eh I played around with it already trying to get the IDC abit lower its only towards top end where boost is already tapered down to 20psi... Around spool up its fine spiking 23-24psi. And me running "leaner" would lower my IDC I would imagine (Im no expert). I just lowered the timing abit and have the car running 20psi Ive got it around 97%. But I can see your point I just need bigger injectors.
Old Nov 17, 2010 | 12:20 AM
ZanarkO's Avatar
^^^^^^ Crap like that boggles my mind. My boost is tapering like that towards redline but Im not making that kind of power.
Old Nov 17, 2010 | 11:57 AM
3gEclipseTurbo's Avatar
I could still add fuel till around 164% idc, this is where the afr wouldnt change at all. And again this was not on purpose, I was not logging idc as my laptop at the time was extremely slow and I was logging as few things as possible, rpm, load, afr, timing, knock.
Old Nov 19, 2010 | 10:35 PM
Guru Johnson's Avatar
Give yourself some room, get 1200's instead.
Old Nov 20, 2010 | 10:28 AM
ZanarkO's Avatar
Eh You get an adjustable fuel pressure regulator and bump it up the ID's flow wise are good up to about 1500-1600 cc's.
Eddis
Oct 15, 2013 08:38 PM
mxguy1286
Jan 18, 2012 06:47 PM
markyang83
Oct 30, 2011 07:42 AM
dubbleugly01
May 8, 2010 03:28 PM
Hirev Evo4
May 15, 2003 12:59 PM
