Cant read/ Write to ECU!!
Old Dec 12, 2010 | 03:02 PM
Mitsu.kid.02's Avatar
Ok, so after i blew a main fuse, i replaced it, car runs fine, no problems. I can log in EvoScan so i figured the ECU is working and is ok. I go to try to Re-Flash the ECU and it wont work. It sends some sequences, then it stops and tells me it wont work.
When i blew the main fuse, the re-flash cable was not plugged into the ECU/ however the regular OBD-2 connection was, so i doubt i fried the cable because everything reports back in EvoScan with no problems. did i break the ECU? is there a relay or fuse somewhere that i may have blown before the ECU? i checked all the fuses were ok. Any ideas?!?
Old Dec 13, 2010 | 09:05 AM
Any ideas guys?
Old Dec 13, 2010 | 09:09 AM
jasserv's Avatar
On my friends IX I had to download and run ecu unlock in the background in order to get it to read the ECU. Whats the exact error its giving you?
Old Dec 13, 2010 | 09:13 AM
Here is the EXACT message:
sending init sequence 1 (0001)
sending init sequence 1 (0003)
sending init sequence 1 (FFFF)
"no response to any known code"
I have heard sometime if the batt voltage is a bit low it wont flash or read but, with the car running it while the volts were 14.2 it still would not read or flash. However i can log just fine, so i dont think the ECU got hurt when the main fuse poped, do you think i need a new taxtric cable? How can i check my cable?
