96530706 Boost issue
Old Dec 14, 2010 | 09:07 AM
AlexEvo6's Avatar
ok, after long searches, I feel quite alone to have this problem. 9417 has difficulties on this topic but not 96530706 AFAIK.
While tuning my boost with this rom and a 3 port GM BCS, it came up to me that the WGDC the ecu "asks" in 3 gear where in fact the "2 gear" values in the rom.
So I log GEAR and RPM_SPEED_RATIO_AVERAGE (using the xml provided for evoscan in the V7 thread).
The RPM / SPEED values were good (compared to the settings in the RPM SPEED to GEAR table), but the GEAR record was not.
In fact, while driving in gear 1 or 2, GEAR show 1. It shows "2" on 3rd gear, and then "3" on 4th and 5th gears.
I tried to lower the ratios in the rom but it's still the same issue.
Rom and xml is the one provided in the V7 thread post #2
the car is a EUDM evo VI, with 04 USDM VIII ecu and 96530706 rom.
MUT 40, 42 and 43 are 8447, 8448 and 8449.
I tried to search and I also did many log / reflash with no success, maybe it's deeper in the code
EDIT
I found some elements but it's still not clear to me.
ECUflash is set rpm/ mph
evoscan is rpm/ kph, I've modified it in rpm/mph (not re logged yet), but I can't understand why it wouldn't work in the rom, because I use the "standard" rpm/speed values in the V7.
0 6
43 5
62 4
85 3
117 2
176 1
2900 0
I can "convert" my logged rpm/kph in rpm/mph and it gives the same values as in the rom table.
I'll try any suggestion
Old Dec 17, 2010 | 06:42 AM
burgers22's Avatar
My thought is the tephra ROMs are for cars in USDM or EDM markets, and perhaps the JDM cars need diffrent RPM/MPH setting, I'm just trying the RPM/MPH multiplied by 0.62 as I have a similar issue on my JDM VII
Old Dec 17, 2010 | 08:34 AM
AlexEvo6's Avatar
In fact I was logging and using rpm/mph, no issue here.
My rpm/speed ratio average value were a little bit off, now with the average logged values it's fixed.
tephra
Apr 22, 2026 11:03 AM
03whitegsr
Oct 8, 2017 08:16 AM
Raceghost
Jul 29, 2016 12:04 PM
roni4g63
Nov 14, 2015 11:45 AM
mrfred
Mar 11, 2015 10:32 AM
