twin BCS evo's
Old Jan 23, 2011 | 04:23 AM
tephra's Avatar
twin BCS evo's
Hi Guys,
Quick Q:
For twin BCS evo's (ie JDM 8, UK 9) is the active solenoid logged as MUT86?
The correction is only applied to the active solenoid right? (hence its name)
Cheers
D.
Old Jan 23, 2011 | 06:13 AM
Jumperalex's Avatar
wait ... what? Tephra isn't that a question *we* are supposed to ask *you* :O
Old Jan 23, 2011 | 06:47 AM
tephra's Avatar
I can't be bothered look at the code... but if no-one knows I will run it through the sim
Old Jan 23, 2011 | 02:42 PM
ziad's Avatar
what u have a sim
Old Jan 23, 2011 | 11:22 PM
VGergo's Avatar
Originally Posted by tephra
Hi Guys,
Quick Q:
Cheers
D.
I replace the active solenoid with a 3port in an Evo 9 RS , and everything is fine the correction is working too, but I upload your V7 rom too.
Old Jan 24, 2011 | 12:17 AM
tephra's Avatar
and does your MUT86 log the 3port/active solenoid?
Looks like I will have to sim it to be 100% sure
Old Jan 24, 2011 | 02:37 AM
ziad's Avatar
hmmm it could just be my car.... u know we both special
Old Jan 24, 2011 | 10:22 AM
VGergo's Avatar
Yes I can log it on mut86 100% sure with the 88580714 rom !
Tephra coud you look after speed density patch for 88580714 for these non usdm evo 9 ? We have psi based boost control. Only need the speed density some times and MrFred wideband controlled closed loop patch. Ready to send donation for it !
Old Jan 24, 2011 | 12:42 PM
Benja's Avatar
Shhhh!!
He's finishing 9055 V7 as his first priority atm!
Old Jan 24, 2011 | 09:31 PM
donner's Avatar
+1
Also for me 88580714 SD would be great! I have already ported livemapping on it, now just SD is missing...
Old Jan 25, 2011 | 06:01 PM
tephra's Avatar
I have done the SD stuff for 88580014 already, ages ago.. its a slightly different method to jcsbanks original, but mostly the same.
I would be happy to share the tables/addresses and someone can get it working properly...
But you really need disasm skills otherwise you will have problems..
Old Jan 25, 2011 | 09:30 PM
donner's Avatar
I have checked your tables/addresses from jcsbanks original thread SD - first success or something and those addresses there are great help to get started. Do you mean those addresses or you have some others? Some table of those was still unclear for me (I'm on other computer now and cannot check) and with my minor disasm skills I did not agree with that as in other SD roms it was done other way. I will check later what I meant but most of this job is already done with those tables (like trouble code disabling and stuff). Anyway if someone starts porting this stuff it should be done to support DMA in my opinion as tuning would be then much easier and faster.
I also noticed that method has changed on it's way, do you still remember differencies between yours and jcsbanks latest (or have I misunderstood something)? Is there any benefit of using some newer method?
Old Jan 27, 2011 | 07:29 AM
burgers22's Avatar
Originally Posted by Benja
Shhhh!!
Old Feb 5, 2011 | 06:03 AM
tephra's Avatar
so after reviewing the code for 96260009 I *think* the WGDC tables that are 100% as stock are the active (ie affected by correction) solenoid
that also links to MUT86 as far as I can tell...
tephra
Nov 27, 2009 07:24 PM
juyanith
Sep 29, 2009 06:27 AM
SkyNight
Feb 20, 2009 04:56 AM
CooLeh7
33
Nov 6, 2008 05:22 AM
mrfred
Sep 29, 2008 11:50 PM
