twin BCS evo's
Hi Guys,
Quick Q: For twin BCS evo's (ie JDM 8, UK 9) is the active solenoid logged as MUT86? The correction is only applied to the active solenoid right? (hence its name) Cheers D. |
wait ... what? Tephra isn't that a question *we* are supposed to ask *you* :O
I can't be bothered look at the code... but if no-one knows I will run it through the sim :) |
what u have a sim :)
Originally Posted by tephra
(Post 9012315)
Hi Guys,
Quick Q: For twin BCS evo's (ie JDM 8, UK 9) is the active solenoid logged as MUT86? The correction is only applied to the active solenoid right? (hence its name) Cheers D. I replace the active solenoid with a 3port in an Evo 9 RS , and everything is fine the correction is working too, but I upload your V7 rom too. |
and does your MUT86 log the 3port/active solenoid?
Looks like I will have to sim it to be 100% sure :) |
hmmm it could just be my car.... u know we both special :)
(Post 9014693)
Looks like I will have to sim it to be 100% sure :) Tephra coud you look after speed density patch for 88580714 for these non usdm evo 9 ? We have psi based boost control. Only need the speed density some times and MrFred wideband controlled closed loop patch. Ready to send donation for it ! |
Originally Posted by VGergo
(Post 9015719)
Yes I can log it on mut86 100% sure with the 88580714 rom !
Tephra coud you look after speed density patch for 88580714 for these non usdm evo 9 ? We have psi based boost control. Only need the speed density some times and MrFred wideband controlled closed loop patch. Ready to send donation for it ! He's finishing 9055 V7 as his first priority atm! :p |
(Post 9015719)
Also for me 88580714 SD would be great! I have already ported livemapping on it, now just SD is missing... |
I have done the SD stuff for 88580014 already, ages ago.. its a slightly different method to jcsbanks original, but mostly the same.
I would be happy to share the tables/addresses and someone can get it working properly... But you really need disasm skills otherwise you will have problems.. |
(Post 9020324)
I would be happy to share the tables/addresses and someone can get it working properly... But you really need disasm skills otherwise you will have problems.. I also noticed that method has changed on it's way, do you still remember differencies between yours and jcsbanks latest (or have I misunderstood something)? Is there any benefit of using some newer method? |
Originally Posted by Benja
(Post 9016185)
Shhhh!!
so after reviewing the code for 96260009 I *think* the WGDC tables that are 100% as stock are the active (ie affected by correction) solenoid
that also links to MUT86 as far as I can tell... |
| All times are GMT -7. The time now is 02:26 AM. |
