problem with morning start
Old Jan 27, 2011 | 02:59 AM
DenisEvoIV's Avatar
I have a problem with morning start, it consists in the following.
I launch the engine, there are on heating turns of 1400 rpm. At achievement coolant temp 45-50 degrees happen the following, turns fail to 600 turns and AFR escapes with 13,8 - 14,2 to 12, 5 11,5. Also it is all happens before the full warming up of the engine, after an engine output on working temperature if to deafen the engine and to start again AFR quits on the worker 14.7. If the engine not to suppress, AFR and turns and remain 600 about, AFR 11,5, and can and decay absolutely.
Where also what parameters to correct what to remove this bug?
EVO IV, tephra mod 7 96530706, MAF JDM ЭВО4, ECU USDM EVO VIII, injector 560 stock.
Old Jan 27, 2011 | 04:22 AM
DenisEvoIV's Avatar
Log
Old Jan 28, 2011 | 02:33 AM
DenisEvoIV's Avatar
Guys, help me defeat this bug, really got it. Although the direction tell where to look?
Old Jan 29, 2011 | 04:08 AM
DenisEvoIV's Avatar
Thanks to all that have not responded. Himself found out, and tables where the corrected parameters. Everything worked perfectly well.
Old Jan 29, 2011 | 04:10 AM
DenisEvoIV's Avatar
Moderators, please close the topic.
Old Jan 29, 2011 | 11:09 AM
EvO9 PiPER's Avatar
LOL
