Openport 2.0, SD Card logging and logcfg.txt
Old Feb 14, 2011 | 04:39 AM
bleunetizen's Avatar
Hi guys
Just trying to figure out how to use the SD card logging feature of openport 2.0..
After doing some search, I figured that you need to put logcfg.txt in the root directory of the sd card, and that file holds information of what should be logged.
I have found a sample logcfg.txt file for an Evo10, which I assume will be different than Evo 9. My looking at the file, it seems like it specifies memory address which it should read from. Is this correct? if it is, how do I figure out what to log?
Is there anyone who got the sd card logging to work on an Evo 9?
Or could anyone post a sample logcfg.txt file for an evo 9 please
Old Feb 14, 2011 | 05:49 AM
dimacoupe's Avatar
my log, for example. evo 9 edm 2006.
File Type: txt
Old Feb 15, 2011 | 04:43 AM
thanks so much for the file.
In your file, i see a parameter below-
paramname=WBO2
paramid=0x3C
scalingrpn=x,0.0392156863,*,9.6,+
is that for logging AFR from a wideband? if so, how do you hook up your wide band with openport2.0?
Thanks in advance, so nice to see people who are willing to help in the evo scene..!
Old Mar 11, 2011 | 03:33 AM
vd's Avatar
vd
Even though you asked not me, I can tell you the answer. WBO2 is wired directly into the ECU in the RearO2 ADC. This way you can easily log AFR from WBO2 along with other parameters from the ECU.
As well in this case you can use the WBO2 for the AFR safety feature in Tephra ROMs.
paramname=WBO2
paramid=0x3C
Old Mar 21, 2011 | 11:30 AM
Armanc1's Avatar
Can anybody point me where I can read how to upgrade the firmeare on my OP2.0? Seems that it is not up to date as I can not get to log to SD card.
Old Mar 22, 2011 | 02:25 AM
vd's Avatar
vd
Firmware update is included in the new versions of Ecuflash, for example 1.43.3150beta include firmware update for the OP2 as well.
Source - http://www.tactrix.com/index.php?opt...d=44&Itemid=65
Old Mar 22, 2011 | 05:02 AM
Oracle1's Avatar
How do you get it to log zeitronix wideband and boost?
Old Mar 22, 2011 | 12:55 PM
vd's Avatar
vd
WBO2 wired into RearO2 ADC input in the ECU + MAP sensor wired into its stock (for USDM and JDM) location in the ECU = happy logging
Old Mar 23, 2011 | 07:58 AM
goodhart's Avatar
So all you have to do is place the lofcfg.txt file above in the root directory of the micro SD card, load "Mode 23" onto your XML file (Is it the same code for an 8/9 as it is a X?), have the beta ECU FLash 1.43.1350 and you are good to go?
Am I missing something?
Old Mar 23, 2011 | 08:09 AM
goodhart's Avatar
Also, what triggers are you guys using? Or are you just going from start to stop? I know the X guys use the cruise control. Is there anyway possible we could use something like the rear defrost or something to trigger?
There needs to be a how-to for this!
Old Mar 23, 2011 | 12:11 PM
Armanc1's Avatar
I have latest Beta, but how do I update the firmware on the OP2 still not clear for me, sorry What are the steps after opening the Ecuflash program?
Old Mar 23, 2011 | 08:56 PM
tephra's Avatar
My personal preference is to ALWAYS log.
Yes it makes going through the logs to find what you need more difficult, but its better to have more information than less.
If you only wanted to capture WOT logs, you could just trigger on TPS.
I guess you could wire up a switch to the ECU if you really wanted a seperate trigger device..
Old Mar 24, 2011 | 05:49 AM
goodhart's Avatar
So Tephra, do you know anything about using this standalone on the CT9A?
If so, does this sound about right?
Old Mar 24, 2011 | 05:51 AM
tephra's Avatar
no for CT9A there is no such thing as mode23.
You will need to use MUT requests
check out the mitsubishi k-line logging file in:
C:\Program Files\OpenECU\EcuFlash\samples\logging
That should give you a decent base to work from...
Old Mar 24, 2011 | 02:14 PM
Armanc1's Avatar
How do I log LC-1 with OP2 to SD card? What line shall I add to the logcfg.txt? Can I plug it directly into mini-plug socket?
