Wideband/Evoscan Problem
Old Mar 12, 2011 | 06:40 AM
escodotcarter's Avatar
bump for some gurus to chime in....
Old Mar 12, 2011 | 10:26 AM
Kings Fan's Avatar
Have you tried mitsulogger's aem logger? Try that and see if it logs. I've found that it logs better than evoscan sometimes. Use that to diagnose that all your connections are correct. http://www.aktivematrix.com/forum/po...p?topic_id=480
There are also several more threads on problems with logging AEM in evoscan, you might want to search for those. Getting AEM to log right in evoscan can be a nightmare.
Old Mar 12, 2011 | 02:32 PM
just tried mitsulogger and the log is showing 14.8 all the way down.
Old Mar 12, 2011 | 03:20 PM
bump
Old Mar 12, 2011 | 03:32 PM
Kings Fan's Avatar
Are you using the blue wire? Hook up a multimeter to the blue wire and see what the output is.
Old Mar 14, 2011 | 08:56 AM
yes im using the blue wire.........going to bestbuy today and buying a different wire. Im currently using a cheap 3 dollar ebay one. Keeping my fingers crossed.
Old Mar 15, 2011 | 11:07 AM
Ralph's Avatar
Solution: downgrade to evoscan 0.99. I had the same problems and that was the only way the uego would Datalog correctly. Evoscan 2.1, 2.5, 2.7 and 2.8 would not log correctly or not even start the logs. Search forums for a link to 0.99.
Old Mar 15, 2011 | 11:30 AM
I will give it a try
Old Mar 15, 2011 | 11:56 AM
BEISSEN's Avatar
I had Tux Evo Wire mine up for me. I have the older UEGO before the Quick Connect came out and I used the Blue wire and the Black wire for the ground but the ground still needs to be connected for the UEGO to work I am useing EvoScan 2.7/8 and I clicked the external wideband monitor box and it reads 99% accurate the WB02 is off completely.
Old Mar 15, 2011 | 11:59 AM
how is it connected to your computer? Im using serial to usb adapter which i think could be the problem.
Old Mar 15, 2011 | 12:02 PM
BEISSEN's Avatar
I used the 9pin to USB cable and it works, Just select the WB you are useing and then check what com port it is in and make it the correct port it will then read.
Old Mar 15, 2011 | 12:20 PM
that is exactly what i did and its not reading. I know its not the gauge or wiring because it works perfectly in mitsulogger.
Old Mar 15, 2011 | 12:32 PM
BEISSEN's Avatar
I dont know as one of the Gurus for more help.
Old Mar 20, 2011 | 07:09 PM
Beebo05's Avatar
are you selecting the external wideband when logging?
Old Mar 20, 2011 | 07:14 PM
sure am
