issues with my ecuflash...
Old Mar 11, 2011 | 07:05 PM
DREVO978's Avatar
Question issues with my ecuflash...
wats up everyone.. so i went today to try to upload my map from my ecu.. and it didnt up load.. a column came up with blank areas.. now my battey died a week ago and i recharged it.. but not sure if it is low again.. i have a small battery in it.. i have no idea y its acting up.. never delt with this issue before..
here is the pic of wat came up..
Old Mar 12, 2011 | 10:38 AM
DREVO978's Avatar
Any info.... Anybody....
Old Mar 12, 2011 | 10:44 AM
blacksunset's Avatar
Try and let the car idle for about 5-10 mkns and try again, my car had a similar issue and it's bcuz the battery was low, once you hook up, engage Ecuflash and upload rom file and Ecuflash will automaticlly turn you engine off. It worked for me and that came from a reputable shop as well
Old Mar 12, 2011 | 10:45 AM
I do believe Ecuflash works off of at least 12v and the higher the better, good luck man
Old Mar 12, 2011 | 05:56 PM
DREVO978's Avatar
Yea I was going towards the battery being low .. I'm gona try it.. I just got nervous cause i never seen it before.. Thanks guys for the help..
Old Mar 13, 2011 | 06:33 AM
burgers22's Avatar
Looks like the read_evo xml is in a different folder to the one you have specified in the amls folder options. The read xmls are in a read templates folder which is usually in C:\Program Files \OpenECU\EcuFlash\rommetadata or C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata for Win 7. You need that folder and it's contents copied to the path for the rest of your xmls.
Old Mar 13, 2011 | 10:06 AM
DREVO978's Avatar
Oh.. So do I just copy and paste it on the evo folder...I copied all the contents on the template folder and pasted it on the evo folder..its that right or am I making things worse lol
Old Mar 13, 2011 | 10:19 AM
chrisw's Avatar
If you screw up too bad, you can try to re-install ecuflash. that will restore all the XML files to their original state. If you have modified any of the XML files, you can copy the modified files on top of the fresh re-installed ecuflash to restore the settings for your car.
Old Mar 13, 2011 | 10:33 AM
DREVO978's Avatar
I did.. I uninstalled it..and put a new one in and it still did it. . I copied those files ova..I'm gona try it in a few min and hopefully it works..
Old Mar 13, 2011 | 12:58 PM
DREVO978's Avatar
ok so copying the files ova didnt work.. so i just deleted everything of my computer and reinstalled it all even evoscan.. so im gona try it again.. see if it works now... has anyone ever have this issue
Old Mar 16, 2011 | 01:29 AM
Wow, I havent seen this before, this might sound stupid but what did you do last in Ecuflash that you might have changed since the last time you ran it, or is this the first time you've used it?? (No pun intended)
Old Mar 16, 2011 | 01:31 AM
I might be wrong but it might have died on you or you made it a brick,
Do you have an OBD2 auto scanner too hook it up too just to attempt to reach the ecu and see if it is responding correctly,
Are your previous rom files saved as hex files or XML
Old Mar 17, 2011 | 03:17 PM
DREVO978's Avatar
everything was working fine.. i honestly have no idea wats goin.. i did the obd patch on my ecuflash and came out fine.. then i tried doin the tephra v7 on it.. and didnt install ok.. so i deleted everything.. and reinstalled it again... and the i tried to upload my ecu and nothing.. i have no clue wats goin on..
Old Mar 17, 2011 | 06:36 PM
DREVO978's Avatar
is this like a new issue or sumthing lol.. did i burn my ecu or sumthing.. this is crazy.. any help.. please.. this thing got me going crazy... im about to just go buy an aem and end it with this ecuflash lol..
Old Mar 22, 2011 | 06:19 PM
DREVO978's Avatar
no one knows wat this is?.. or wat is the cause of this..
