immobilizer delete problems!!!
Old Apr 6, 2011 | 07:53 PM
indcent's Avatar
to start with .. i think ive read everything there is to read on the subject and im still in the woods here.. ive added extra lines to the .xml file and altered the rom to 0x56d2 and ive tried adding other code to the xml as well.. i cant seem to find anything that works.. ive got the original rom im working with and the altered xml as well.. see i bought a 2000 eclipse gs auto without an ecu in it.. so i dont have the original ecu code for the immobilizer.. i know that a 2000 ecu is non-flashable so i purchased an 01 eclipse ecu gs auto... i found a stock rom for the gs and flashed in the new hex code to disable the immobilizer.. ive had a guy from here take a look at it and work on it a bit and we are stuck.. i still cant get fuel into the injectors.. can someone please look at this and see if you can see what im doing wrong
Old Apr 6, 2011 | 07:56 PM
indcent's Avatar
it would not let me upload the xml file.. so here is the copy paste version
<rom>
<romid>
<xmlid>85850013</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>85850013</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Eclips</model>
<submodel>GS</submodel>
<transmission>Auto</transmission>
<year>2001</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
<table name="High Octane Fuel Map" address="35cb" level="2">
<table name="Load" address="5618" elements="10"/>
<table name="RPM" address="5566" elements="14"/>
</table>
<table name="Low Octane Fuel Map" address="3663" level="2">
</table>
<table name="High Octane Ignition Map 1" address="3b43" level="2">
<table name="Load" address="57da" elements="12"/>
<table name="RPM" address="57ac" elements="18"/>
</table>
<table name="Low Octane Ignition Map 1" address="3c27" level="2">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="3844"
level="3">
<table name="Battery Voltage" address="56d0" elements="7"/>
</table>
<table name="Rev Limit" address="156a" level="3"/>
<table name="Accel Enrichment" address="38dc" level="1">
<table name="RPM" address="5af0" elements="10"/>
</table>
<table name="Open Loop Load # 2" address="3750" level="1">
</table>
<table name="Desired ISCV intial step position with AC off-Neutral"
address="3e1a" level="1">
<table name="Engine Temp" address="58d0" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive"
address="3e28" level="1">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral"
address="3e36" level="1">
</table>
<table name="Desired Idle RPM-Neutral" address="3e44" level="1">
</table>
<table name="Desired Idle RPM-Drive" address="3e0c" level="1">
</table>
<table name="Open Loop Load # 1" address="373a" level="1">
</table>
<table name="Stationary Rev Limit" level="1"/>
<table name="Open Loop Throttle Low Load" address="376c" level="1">
</table>
<table name="Open Loop Throttle High Load" address="3782" level="1">
</table>
<table name="Desired Idle RPM with AC on" address="1820" level="1">
<table name="Condition"/>
</table>
<table name="High Intake Air Temp Idle Speed Target" level="1">
</table>
<table name="High Intake Air Temp ISCV Increase" level="1">
<table name="Condition" elements="2"/>
</table>
<table name="Min Coolant Temp for Closed Loop" address="1588" level="3"/>
<table name="Injector Scaling" address="1506" level="3"/>
<table name="Speed Limit" address="156c" level="3">
</table>
<table name="Air Temperature Compensation" address="354e">
<table name="Degrees" address="5916" elements="7"/>
</table>
<table name="Barometric Pressure Compensation" address="3561">
<table name="Atmosphere Pressure" address="566e"/>
<table name="RPM" address="56b4"/>
</table>
<table name="Idle Stepper Look-up Table" address="3f11">
<table name="Throttle Position" address="587a"/>
<table name="RPM" address="5962"/>
</table>
<table name="MAF Sensor Filtering" address="1508">
<table name="Load"/>
</table>
<table name="MAF Size" address="150c"/>
<table name="Immobilizer" level="2"/>
<table name="MAF Scaling" address="3516" level="1">
<table name="Load" address="5680"/>
</table>
<table name="MAF Smoothing Table" address="3532" level="1">
</table>
<table name="IC Relay Timer ON Mode Switch Time"/>
<table name="IC Relay Timer Control RPM"/>
<table name="IC Relay Timer Control Water Temp">
</table>
<table name="IC Relay Control Vehicle Speed"/>
<table name="IC Relay Control EV"/>
<table name="IC Relay Timer Time">
</table>
<table name="IC Relay Timer Control Judgement">
</table>
<table name="IC Relay Timer Air Temp"/>
<table name="Knock Sensor Filter Map 1" address="432d">
<table name="TAR" address="5b10" elements="9"/>
<table name="RPM" address="5af0"/>
</table>
<table name="Knock Sensor Filter Map 2" address="439b">
</table>
<table name="Knock Sensor Filter Map 3" address="4409">
</table>
<table name="Knock Sensor Filter Map 4" address="4477">
</table>
<table name="Knock Sensor Filter Map 5" address="44e5">
</table>
<table name="Knock Sensor Filter Map 6" address="46df">
</table>
<table name="Knock Sensor Filter Map 7" address="474d">
</table>
<table name="Knock Sensor Filter Map 8" address="47bb">
</table>
<table name="Knock Sensor Filter Map 9" address="4829">
</table>
<table name="Knock Sensor Filter Map 10" address="4897">
</table>
<table name="Knock Sensor Filter Map 11" address="4905">
</table>
<table name="Fuel Table #3 ?" category="Fuel" address="4fa1" type="3D"
level="1" swapxy="true" scaling="AFR">
<table name="Load" address="5618" type="X Axis" elements="10"
scaling="Load"/>
<table name="RPM" address="5566" type="Y Axis" elements="14"
scaling="RPM"/>
</table>
<table name="Ignition Map #3 ?" category="Timing" address="5039" type="3D"
level="1" swapxy="true" scaling="Timing">
<table name="Load" address="57da" type="X Axis" elements="12"
scaling="Load"/>
<table name="RPM" address="57ac" type="Y Axis" elements="18"
scaling="RPM"/>
</table>
<table name="Immobiliser Code Removal" category="Rom Information" address="faa" type="1D" level="1" scaling="Hex16" />
</rom>
Old Apr 12, 2011 | 03:42 AM
rolly1818's Avatar
Registered User
bump for some help here.
Old Apr 12, 2011 | 02:03 PM
todd6027's Avatar
in misc section immobiliser try ffff (enter as 0xffff) does the fuel pump run ???? if it doesnt swap ecu pins 8 and 22
Old Apr 14, 2011 | 08:17 PM
indcent's Avatar
fuel pump is running.. still didnt start.. not sure what else to do
richardjh
Sep 17, 2023 01:02 AM
1gcrazy
Jan 13, 2017 12:18 AM
mady4g63
Nov 27, 2014 12:38 AM
secretagentstv
Oct 5, 2014 12:13 PM
(GSX95)
Nov 26, 2012 06:51 PM
