What controls A/F ratios at higher loads?
Old Apr 13, 2011 | 12:06 AM
scrivs's Avatar
What contols A/F ratios at higher loads? When my engine goes from vacuum through 0 psi into boost, she goes *very* lean and will start to knock badly if I leave my foot in it. Its a fueling issue and I'm at the point where I don't know where else to look.
Thanks mates!
Old Apr 13, 2011 | 12:31 AM
evo8426's Avatar
post up logs and your rom. that will help get your issue resolved
Old Apr 13, 2011 | 01:18 AM
Benja's Avatar
Original fuel pump?
Old Apr 13, 2011 | 02:32 AM
todd6027's Avatar
lean spool
Old Apr 13, 2011 | 02:54 AM
scrivs's Avatar
Thanks for the help. I can post up the rom, but it knocks too much to properly do any sort of pull... Anything more than about 20% throttle will make her lean out. Mods are GT3076r, gsc 1 cams, wally 255, 880cc injectors.
Old Apr 13, 2011 | 02:55 AM
scrivs's Avatar
Originally Posted by todd6027
lean spool
Nah, I wish.
Old Apr 13, 2011 | 04:09 AM
recompile's Avatar
Check the vacuum line on the fuel pressure regulator. Fuel pressure may not be increasing with boost like it should be.
Old Apr 13, 2011 | 05:51 AM
todd6027's Avatar
Originally Posted by scrivs
Nah, I wish.
take out some timing and richen it up if everything else is ok fpr lines etc
Old Apr 13, 2011 | 06:08 AM
raasfaas's Avatar
+1
definitely sounds like the vacuum line fell off.
Old Apr 13, 2011 | 02:48 PM
scrivs's Avatar
Vacuum lines are good, fpr is new... Boost leak test ok...
Old Apr 14, 2011 | 04:11 PM
RyuEvoIX's Avatar
Check your injectors and fuel pump grommet.
Old Apr 14, 2011 | 10:41 PM
3K's Avatar
3K
Is your fpr adjustable? did you adjust it?
Old Apr 20, 2011 | 12:41 AM
scrivs's Avatar
No, its a new oem fpr
Old Apr 20, 2011 | 11:54 AM
raasfaas's Avatar
lean spool
Nah, I wish.
Does that mean that leanspool is enabled or disabled?
Maybe you should post a log along with your maps so we can get a better picture of what's going on.
Old Apr 20, 2011 | 11:59 AM
andrewzaragoza's Avatar
what was changed before this issue occurred?
