Logging Issues with Tephra V7 94170715
Old May 8, 2011 | 11:45 AM
criptballer's Avatar
Question Logging Issues with Tephra V7 94170715
Ok guys, first off sorry if this has been talked about before or for the fact that i might be retarded and it might be a simple fix that's out there somewhere. I searched for the info but some threads have hundreds of pages and i'm not sure i have the time to look through all of them.
A month ago i uploaded the tephra v7 94170715 off of the first page from the original thread. It's working great but i'm having issues logging some stuff and using Map tracer.
After i loaded the V7map i did a wot pull and tried using maptracer with evoscan 2.6 beta 6 (didn't know there were new ones out). it logged some stuff but they were funky. The values would would only show on the 0 rpm cell but did follow the load axis. I made sure that the byte rate was the same under ecuflash and the load value in evoscan which it was, at 1.2. So then i downloaded version 2.8.0005 and tried the same thing. still nothing. my boost is also not logging properly. none of them, i know there is about three of them. Interesting fact i found was that they all use the same request ID but the formulas differ. Then today i tuned my brothers Evo X with the new version of evoscan and map tracer worked just fine.
so my questions are,
How do i log boost properly with V7 and rom ID listed above?
do i have to be logging 2byte in order for Maptracer to work and that's why my brothers works since he's on mode23?
or should i be using evoscan version 2.7 for this to work?
are there any other changes i should know about that i need to make?
ps. i tried to follow all of the instructions i have found for uploading this, I don't think i missed anything but maybe i did along the way. Thanks for any help!
Old May 8, 2011 | 12:06 PM
well, one problem solved. You apparently need to use evoscan 2.7 in order to use maptracer.
Now, how do i log boost correctly?
Old May 8, 2011 | 12:13 PM
LGshow19's Avatar
Some Evoscans act differently and you may have to go to a newer or older version sometimes. Also uninstalling them and reinstalling them works.
As for logging boost. Do you have a 3bar map sensor(JDM Map sensor)? that is what the evo8/9s need in order to log boost via evoscan. Evo10s can log boost straight from the factory since they already have a 3bar map sensor.
Old May 8, 2011 | 12:37 PM
ahhh i see. so if i have tha oem map sensor then i won't be able to properly log boost is what you're saying?
in that case. should i just go with an omni 4bar sensor since i plan on runing 30 plus?
Old May 8, 2011 | 12:50 PM
LGshow19's Avatar
I forgot how much the 3bar map sensor can read, but i know it can read 30+ since i have done it.
I will find the link about the 3bar map sensor... hold up.
EDIT: the 3bar only reads up to 32psi.
Old May 8, 2011 | 12:57 PM
LGshow19's Avatar
Heres the Link:
https://www.evolutionm.net/forums/ec...tructions.html
Also, the 3bar sensor only goes too 32psi, so go head and get the Omni 4 bar.
Old May 8, 2011 | 01:52 PM
Thanks for the help man. Do you know if you can use the regular WGDC type of boost control with an omni 4 bar? i was reading on the V7 thread but they talk about direct boost through the ecu and i'm not familiar with it but was wondering if i would be able to control it the old way with wgdc.
Old May 8, 2011 | 02:19 PM
LGshow19's Avatar
Are you talking like still using the MBC to control boost?
Old May 8, 2011 | 04:31 PM
no, not a manual boost controller. I mean like a grimmspeed 3 port electronic boost controller. just adjusting the wgdc depending on gear and rpm. But i think the answer is yes, after doing some reading.
Old May 8, 2011 | 04:50 PM
LGshow19's Avatar
Oh ight, but yeah you can. i know there are multiple tuning methods for ecu controlled boost.
roni4g63
Nov 14, 2015 11:45 AM
drifterific
Sep 1, 2010 06:05 PM
goevox
Mar 9, 2010 06:42 PM
chmodlf
Aug 24, 2008 01:17 PM
7oey
Jan 27, 2008 05:16 AM
