9417 and dual map boost questions
Old May 18, 2011 | 07:29 PM
mxguy1286's Avatar
Ok im running the 9417 on v7 with s.d and I am trying to set up my boost control on dual maps. My question is how do I go about setting this up correctly as the b.d.e only allows for 28 psi. and I want 27 psi on the main map and 35 psi on my alternate map? I know I need to use the boost adder to get to 35 psi but wont that mess with my main map and only wanting 27 psi on that map? Any help is much appreciated
Old May 18, 2011 | 07:43 PM
Ian0611's Avatar
I would think that you could use the higher boost adder that you need for 35psi and then run lower values in your other BDEL map. The psi values won't look right but as long as the load values add up with the adder you should be fine.
