Logging from my Depo Wideband Gauge
Old May 19, 2011 | 08:10 PM
CRONZ305's Avatar
I have a wideband it uses a Bosch LSU4.9 UEGO Sensor it has a 0-5V output wire.
Depo gauges arent really sold here in the US so its hard to find info.
(0v=10.00afr)
(5v=20.00afr)
it comes with a chart with the volt to gas afr
Ex:
V AFR
0.16 10.32
0.31 10.62
0.47 10.94
ect.
I wanted to know how i can log from it. Can i splice into my ecu rear sensor? i have a test pipe so i dont need use that sensor anyways.
Currently i tried doing it as if it was a AEM i made the cable Serial to USB and that didnt work. Is the formula in EvoScan different? How do i go about logging from my wideband.
Old Jun 1, 2011 | 08:29 AM
CRONZ305's Avatar
Got this fixed. Wired it into the read 02 ecu pin and used same formula as AEM. Works great.
Old Jun 19, 2011 | 05:22 PM
audiofan's Avatar
I'm trying to do the same with a prosport wideband
Can you post more details on how yo did it?
thanks
Old Jul 30, 2012 | 09:48 PM
CRONZ305's Avatar
Bringing this back.
So what i ended up doing is Apply the Rear O2 Sim Patch (Comes with Tephra V7) Then i found the pin that gets info from the rear O2.
I put the output wire from my wideband into the ECU (Rear O2 Pin)
Then on EvoScan instead of using 3C like ive seen on some threads i use 12. (MUT 12 changed to 8409.
Now with all that done im able to pickup my Wideband.
HERES THE PROBLEM!! ...... Ive tried so many formulas to get the gauge to read the same as logged and its been a pain. Also what people use seems to be different for most...
WikdEvo
11
May 21, 2014 01:00 PM
motion3131
For Sale - Cars For Sale
22
Jan 6, 2013 10:22 AM
TTP Engineering
EvoX 'For Sale' Interior Styling
18
Dec 1, 2009 12:45 PM
TTP Engineering
45
Dec 1, 2009 12:32 PM
TTP Engineering
135
Feb 1, 2009 12:07 PM
