LC-1 serial output not same as DB gauge in Evoscan
Old May 29, 2011 | 12:13 PM
BigT's Avatar
As the title says.... The evoscan display does not match my LC-1 DB gauge. My logs show .2 to .3 leaner vs the gauge at all RPMs and loads. Is it safe for me to assume that the serial output is a more correct number vs the guage?
Old May 29, 2011 | 04:45 PM
richardjh's Avatar
Does the DB gauge work off the LC-1 analogue voltage output?
edit:
Answered my own question using the POWAH OF GOOGLE. Yes, it is analogue only. So you're not comparing "gauge to EvoScan" - you're comparing LC-1 "analogue to serial". And your analogue output relies on all that fun grounding stuff to be accurate. My guess is that your voltage reading is offset by a fixed amount. The serial reading will be the accurate one.
Try rejigging your DB wiring, eg. the earth connection - see if a different location gets you closer to the EvoScan display.
I actually ordered an Inno DB gauge. Right after I hit "buy", I noticed the "analog only" text, and pestered Innovate to change my order to a (much more expensive) XD-16... which works off the serial data connection. The funky tri-colour reprogrammable LEDs had nothing to do with my decision. Ahem.
Rich
Old May 29, 2011 | 05:32 PM
C6C6CH3vo's Avatar
Question
Logworks will display the actual AFR serially
Old May 29, 2011 | 06:32 PM
Benja's Avatar
Not to a gauge on the dash though.
Old May 29, 2011 | 06:45 PM
BigT's Avatar
well, i was think that i would rather rely on my logs for tuning(serial output) and use the guage as the day to day monitor.
Old May 29, 2011 | 07:41 PM
richardjh's Avatar
Say, why not just use Inno's LM Programmer utility to adjust the LC-1 analogue output voltage by a hair?
Just tell the LC-1 to send a slightly higher voltage across the entire range, ie. shift the graph line up a wee bit.
Tweak it so that your gauge and serial are exactly in line. Then you can be 100% confident in your day-to-day monitoring.
Rich
stokEd
51
Oct 14, 2015 06:44 PM
3vo|3oost
Apr 4, 2012 05:39 AM
Benja
Apr 12, 2011 06:07 AM
saiyuke
Jul 6, 2008 01:13 AM
gosu.pianist
Feb 21, 2008 06:16 PM
