Bucking or stutter at low load/rpm
Old Jun 6, 2011 | 10:40 PM
Eisen7's Avatar
^ No it's at about 25-40 load, 1900-2000rpm. See log in my 1st post.
Old Jun 6, 2011 | 11:11 PM
utripin's Avatar
Ok, I got it now. Sorry I didn't look at the log...was on my cell, and was unable to read it. Also THAT IS A HUGE AMOUNT OF TIMING! Damn!! Make sure everything else is in order, or you will be just chasing yourself. Back in a sec.....
Old Jun 6, 2011 | 11:29 PM
utripin's Avatar
Try blending/the numbers some...I see a big jump in timing. For part load conditions, it is usually best to find MBT timing for most cases. This allows the engine to operate as efficiently as possible, with optimal fuel economy and good throttle reponse. Good luck! It'll come together.
Old Jun 6, 2011 | 11:38 PM
tscompusa2's Avatar
running max timing at low loads like that is not what you want to do.. you will hurt the engine with misfires. but he does need to just troubleshoot and test what certain changes do. i bet if he loads my old map on it, it wont do it, but then he will have the ac dip but that can be fixed via the idle air controller and base idle set screw.
Old Jun 6, 2011 | 11:49 PM
utripin's Avatar
I see your point.....didn't know the history with the earlier map from you. But I bet if he goes back to it the problem will be sloved. IAC...and base idle set screw.
Why did he change from it? AC dip I'm guessing?
Old Jun 6, 2011 | 11:57 PM
tscompusa2's Avatar
ac dip yes. he likes to tune himself also.. so he tunes himself and does lots of stuff here and there on the car.. he knows what hes doing, but i think he just went the wrong route on the fix for this dip in rpm control issue.
its possible it doesn't cure the issue, but i dont see how not.. but he will update the thread with the fix.. if he cant figure it out ill help him figure it out.
so if you need help Dale just email me.. and we will figure it out. you know me.. i dont give up
Old Jun 7, 2011 | 12:03 AM
utripin's Avatar
Your a GOOD MAN! I'm at work, what's your reason for being up?
Old Jun 7, 2011 | 12:06 AM
tscompusa2's Avatar
i have a retarded schedule + i need to stay up to call the UK regarding a turbo lol. since they are 5 hrs ahead and my schedule is really out of wack, i wont be able to contact them until about 4-5am
Old Jun 7, 2011 | 12:15 AM
Eisen7's Avatar
I'm happy to put back your original settings around the idle areas Tom and see if it sorts this stuttering issue at low rpm. I know you've had good results in getting a steady idle in other threads recently, so I'll follow that process and see where it ends up. If I get a nice steady idle with A/C on or off and it doesn't dip or stall when coasting to a stop with A/C on (clutch in), then I'm no worse off than I am now
Will post up how it goes and email you if I have any dramas. It's Chris by the way (you've got too many clients!)
Old Jun 7, 2011 | 12:20 AM
tscompusa2's Avatar
my bad LOL i thought you were Dale, because hes also from Australia. hopefully it gets sorted out if not we will trouble shoot it directly.
Old Jun 7, 2011 | 12:33 AM
Revo15's Avatar
Mine used to do the same until I cleaned out the throttle body..give it a shot n see what happens...could be the solution rem its always the small n tiny things that causes the big problems..
Old Jun 7, 2011 | 06:20 AM
Nashou66's Avatar
How old are your plug wires?
Athanasios
Old Jun 7, 2011 | 07:06 PM
Eisen7's Avatar
OK I've made a few changes as per tscomp's suggestions in the v7 cold start thread. Basically all I've done is:
- Put a block of 12's back in the idle areas of the ign map rather than the higher values I had.
- Set "Desired ISCV intial step position with AC off-Neutral" to these settings https://www.evolutionm.net/forums/9129618-post30.html
- Set "Desired IDLE Rpm - neutral" all to 1000
Cold start is good and moves down to 1000rpm fairly quickly. It used to rev a bit higher, but my cold starts were generally OK anyway.
I've only driven to work on these settings this morning, but I could not reproduce the stutter/hopping at 1900rpm. Need more time to ensure it's not there. Note that I think the A/C idle might still need some work as it did dip below 1000rpm a couple of times when I switched the A/C on and let the revs drop from high rpm. Still it didn't stall which is a good sign
Old Jun 7, 2011 | 07:16 PM
Eisen7's Avatar
Athanasios
Haven't changed them since owning the car for about 4 years...
Old Jun 7, 2011 | 07:34 PM
Nashou66's Avatar
My MR is 6 years old and last week i went to change my plugs for the first time and this happened :
Have you changed plugs since then as well?
But it seams you may have solved the issue. Hope that was the fix.
Athanasios
