Can we log ABS sensors individually?
Old Jun 27, 2011 | 04:06 PM
Jeff_Jeske's Avatar
I'm having an issue when braking at speeds over 100+ mph where it feels like ABS is kicking in. Removing the ABS fuse eliminates the problem but I'd like to log the ABS to determine WTF is going on.
Old Jun 28, 2011 | 07:00 AM
nightwalker's Avatar
You can with a scan tool, but there is not an option in Evoscan or Mitsulogger.
A couple easy things you can do is check the wheel speed sensor. Sometimes dirt and rust will grow around and underneath it and back it out enough to widen the air gap which can cause problems like you're experiencing.
Just remove the sensors, clean them and the base of their holes <--that didn't sound right.
