Can't read ECU to save my life..
Old Jul 3, 2011 | 11:26 PM
lonestarevo83's Avatar
Post Can't read ECU to save my life..
[01:20:34.443] EcuFlash Version 1.42.2595
[01:20:34.443] OS Version Windows Vista
[01:20:34.443] Qt Version 4.5.0
[01:20:34.457] 56 memory models read.
[01:20:34.457] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[01:20:34.797] 343 ROM metadata models scanned.
[01:20:34.797] checksum module "subarudbw" loaded.
[01:20:34.797] checksum module "mitsucan" loaded.
[01:20:34.797] flashing tool "wrx02" loaded.
[01:20:34.798] flashing tool "wrx04" loaded.
[01:20:34.798] flashing tool "sti04" loaded.
[01:20:34.798] flashing tool "sti05" loaded.
[01:20:34.798] flashing tool "mitsukernel" loaded.
[01:20:34.798] flashing tool "mitsukernelocp" loaded.
[01:20:34.798] flashing tool "mitsubootloader" loaded.
[01:20:34.799] flashing tool "shbootmode" loaded.
[01:20:34.801] flashing tool "shaudmode" loaded.
[01:20:34.801] flashing tool "subarucan" loaded.
[01:20:34.801] flashing tool "mitsucan" loaded.
[01:20:58.866] J2534 API Version: 04.04
[01:20:58.866] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[01:20:58.866] Device Firmware Version: 1.10.3020
[01:21:02.846] sending init sequence 1 (0001)
[01:21:03.037] J2534 error [ERR_TIMEOUT].
[01:21:03.568] J2534 error [ERR_TIMEOUT].
[01:21:03.568] interface close
These are the lines that pop up every time I try to read my ecu. About to have a total makeover on my setup so i need to see where I stand now, in need of a baseline. But every time i try to read I get these errors.. Anyone have any idea's I'm fairly new to the game so please school me.. Class is in session..
Thanks in advance...
JRP
Old Jul 4, 2011 | 12:40 PM
Nobody?
Old Jul 4, 2011 | 01:24 PM
[15:19:15.275] EcuFlash Version 1.42.2595
[15:19:15.275] OS Version Windows Vista
[15:19:15.275] Qt Version 4.5.0
[15:19:15.289] 56 memory models read.
[15:19:15.289] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[15:19:15.624] 343 ROM metadata models scanned.
[15:19:15.624] checksum module "subarudbw" loaded.
[15:19:15.624] checksum module "mitsucan" loaded.
[15:19:15.624] flashing tool "wrx02" loaded.
[15:19:15.625] flashing tool "wrx04" loaded.
[15:19:15.625] flashing tool "sti04" loaded.
[15:19:15.625] flashing tool "sti05" loaded.
[15:19:15.625] flashing tool "mitsukernel" loaded.
[15:19:15.625] flashing tool "mitsukernelocp" loaded.
[15:19:15.625] flashing tool "mitsubootloader" loaded.
[15:19:15.626] flashing tool "shbootmode" loaded.
[15:19:15.627] flashing tool "shaudmode" loaded.
[15:19:15.628] flashing tool "subarucan" loaded.
[15:19:15.628] flashing tool "mitsucan" loaded.
[15:20:00.681] J2534 API Version: 04.04
[15:20:00.681] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[15:20:00.681] Device Firmware Version: 1.10.3020
[15:20:06.680] sending init sequence 1 (0001)
[15:20:09.906] sending init sequence 1 (0003)
[15:20:13.132] sending init sequence 1 (FFFF)
[15:20:16.365] sending init sequence 1 (F0F0)
[15:20:19.082] no response to any known code
[15:20:19.083] interface close
Old Jul 4, 2011 | 02:03 PM
whtrice's Avatar
Veteran: Air Force
There are quit a few threads on this regarding ECU connection problems:
Inspect the wire that goes to the white connector...it is probably open/bad. I have had to repair mine a couple times.
Or......
Try starting the car and then connecting. Low battery voltage may be the cause.
Old Jul 4, 2011 | 02:08 PM
Evo1001's Avatar
i had the same problem at first. Check our tactrix cable and make sure both connectors are plugged in under the dash. Then do a read rom.
When I only had the main one plugged in I got the same errors.
Good luck.
Old Jul 4, 2011 | 05:08 PM
SunnyC's Avatar
i think it's best if you asked it in ecuflash section, i don't think everybody in this section knows or uses it.
Old Jul 4, 2011 | 07:04 PM
O snap, good point. Can a mod please move this. Thanks for the info already guys.
Old Jul 4, 2011 | 07:10 PM
s.lamoureux's Avatar
the cable i got was bad, had to pay $80 to reship it back and i've been waiting months for my replacement. wish someone else made them, guy is a joke.
Old Jul 4, 2011 | 08:11 PM
chaotichoax's Avatar
where on earth did you ship it to that it cost you 80 bucks is the first question?
who did you buy it from?
I had a bad cable and tactrix had a new cable in my hands in 7 business days
Old Jul 5, 2011 | 06:01 AM
it had to be sent to Zew Zealand i believe got it from evoscan
Old Jul 5, 2011 | 10:15 AM
Tried using evoscan when car was started but no luck. ran ecu unlock-er with no luck also.. cable is in good shape. Anything else it could be?
Old Jul 5, 2011 | 10:39 AM
i had the same errors and my cable looked fine but it ended up being faulty.
Old Jul 5, 2011 | 02:46 PM
So can you just Ohm the cable out to find out if its bad or not?
Old Jul 6, 2011 | 09:59 AM
analogEvo's Avatar
your using 1.42 uninstall it and find 1.28 or 1.29 and install it.thats what i had to do 1.42 wouldnt even read my ecu then used a earlier version and it worked perfect. 1.28 or 29 is a more raw version it dosnt have all the new add ons but try it out it might work
Old Jul 6, 2011 | 07:33 PM
Ok, I will try that tomorrow.
