03 read issues
Old Jul 4, 2011 | 12:32 PM
Boostedx11's Avatar
03 read issues
Hey I was recently trying to make some adjustments to the map but for some reason it tries the 3 codes and won't connect. Its an 03 ecu and evoscan works if that helps. I read about the drivers but I couldn't find the older ones. I am currently running the newest version.
Old Jul 4, 2011 | 01:01 PM
lonestarevo83's Avatar
Having the same problem..... spits out a couple codes then ends the session...
Old Jul 4, 2011 | 01:25 PM
[15:19:15.275] EcuFlash Version 1.42.2595
[15:19:15.275] OS Version Windows Vista
[15:19:15.275] Qt Version 4.5.0
[15:19:15.289] 56 memory models read.
[15:19:15.289] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[15:19:15.624] 343 ROM metadata models scanned.
[15:19:15.624] checksum module "subarudbw" loaded.
[15:19:15.624] checksum module "mitsucan" loaded.
[15:19:15.624] flashing tool "wrx02" loaded.
[15:19:15.625] flashing tool "wrx04" loaded.
[15:19:15.625] flashing tool "sti04" loaded.
[15:19:15.625] flashing tool "sti05" loaded.
[15:19:15.625] flashing tool "mitsukernel" loaded.
[15:19:15.625] flashing tool "mitsukernelocp" loaded.
[15:19:15.625] flashing tool "mitsubootloader" loaded.
[15:19:15.626] flashing tool "shbootmode" loaded.
[15:19:15.627] flashing tool "shaudmode" loaded.
[15:19:15.628] flashing tool "subarucan" loaded.
[15:19:15.628] flashing tool "mitsucan" loaded.
[15:20:00.681] J2534 API Version: 04.04
[15:20:00.681] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[15:20:00.681] Device Firmware Version: 1.10.3020
[15:20:06.680] sending init sequence 1 (0001)
[15:20:09.906] sending init sequence 1 (0003)
[15:20:13.132] sending init sequence 1 (FFFF)
[15:20:16.365] sending init sequence 1 (F0F0)
[15:20:19.082] no response to any known code
[15:20:19.083] interface close
What I'm getting...
Old Jul 4, 2011 | 02:26 PM
Boostedx11's Avatar
Exactly the same for me
