Problem trying to Connect LC1 to log from Rear O2
Old Aug 14, 2011 | 06:27 PM
desiromeo812's Avatar
Hi all, I have tried using the Tephra V7 with the option for rear O2 Simulator enabled. For some reason every time i try to log EVOscan freezes. I have Removed ecu pin #73 purple and blue wire and put the output from my LC1 into that pin.
I checked the voltage from the #73 purple wire and it sees Battery voltage. So my thoughts are that I am tapping the incorrect ECU pin. MY LC1 output voltage is correct. I have set up the MUT table for 12 & 3C to 8409.
Please help me find the right wire for my Rear O2.. this is for a Evo IX USDM with a 88590015 Tephra V7 ROM.
Cliffs: Pin 73 (purple/blue) wire showing BAT voltage, which leads me to believe thatI have the wrong wire for rear O2 signal
