Help! Trying to locate (JDM MAP SENSOR)
Old Aug 16, 2011 | 08:54 AM
iziegsx's Avatar
Hey all,
I own a 2003 JDM evo8 and as some of you know the map sensor for the USDM evo8 is on the intake manifold. I have switched over to a Buschur racing ported intake manifold. The map sensor does not have a connector switch and so it is just there (not connected to anything) Could any of you have give me some insight as to what i should. I was hoping to hook up an omni 4 bar and grimmspeed 3port.
Looking forward to some feedback.
Old Aug 16, 2011 | 09:01 AM
chetrickerman's Avatar
Veteran: Army
are you looking for the connector or the MAP sensor?
Old Aug 16, 2011 | 09:04 AM
iziegsx's Avatar
What ever i need to successfully install the omni 4bar. Would be nice to find both though even if i do not need to. Wish i had a FSM for this car!
Old Aug 16, 2011 | 09:31 AM
Veteran: Army
check out this thread
https://www.evolutionm.net/forums/ec...plug-play.html
there are a lot of threads on this in this section
Old Aug 16, 2011 | 08:27 PM
iziegsx's Avatar
Thanks alot man. Im going to check your link and also i found the pin out for my ecu so tomorrow i will check pin 92 and see if it has any wires. Must send a shout out to 4WS tuning for the tech support!
Old Aug 16, 2011 | 08:49 PM
Veteran: Army
happy to help you out
Old Aug 17, 2011 | 01:57 PM
iziegsx's Avatar
For all JDM evo8 owners. Note your car does not have a map sensor. The JDM evo9's however possess one. Attached is the JDM evo 8 ecu pin out.
File Type: pdf
