BC 272 cams on Evo IX
Old Oct 6, 2011 | 07:17 AM
  #31
High_PSI's Avatar
Please correct me if I am wrong but aren’t these cams a poor upgrade? Wouldn’t a GSC S1-S2 line be a much better choice?
Old Oct 9, 2011 | 02:47 AM
  #32
justastockevo's Avatar
Originally Posted by 05blue8
Thanks justastockevo, that's AWESOME!
any luck with these tables? we've tried almost everything and have nothing but marginal improvements. still way worse than stock injectors.
Old Oct 9, 2011 | 07:35 AM
  #33
Dynotech Tuning's Avatar
Originally Posted by KOOLER
I've turned closed loop OFF as some guys here insisted there's no way to tune Evo using stock ECU and 1000+ cc injectors.
You're joking right? I just tuned GSC S3 cams with 2150cc injectors on the stock ECU and I can make them idle like a dream in closed loop. That's a bit harder than what you're trying to do. Whoever told you that has given you false information.
-Jamie
(aka Jack_of_Trades)
Old Oct 10, 2011 | 06:58 AM
  #34
tscompusa's Avatar
closed loop here also:
http://www.youtube.com/watch?v=Ajq-lwdO1XY
e85 - nothing but cranking IPW changes and fires first crank cold and warm.
runs same on 93 as well.
Old Oct 10, 2011 | 02:34 PM
  #35
KOOLER's Avatar
I'm not kidding. Of course I know it's wrong. I did tests but anything strage except I see ~15:1 on idle is not seen. Is it a vacuum leak indication? Map suggests 14.7:1 of course.
-Jamie
maxroach
Jul 22, 2017 05:07 PM
evolved8 bs
Nov 29, 2015 09:55 PM
Dragking2189
Nov 6, 2008 09:19 PM
Aby@MIL.SPEC
Sep 6, 2006 01:31 PM
TD05HR
Northeast Region
11
Dec 10, 2004 06:22 AM
