tuning with det-can tips
Old May 19, 2013 | 05:15 AM
ExViTermini's Avatar
What about substituting a bosch knock sensor in place of the mic?
Old May 19, 2013 | 03:12 PM
merlin.oz's Avatar
Possibly, but they are less sensitive than a microphone (typically) and so the amplifier module would need more gain.
I guess you would have to experiment and see what result you get.
Old May 19, 2013 | 04:54 PM
Dynotech Tuning's Avatar
Not all knock sensors are created equal. They have different natural resonant frequencies. Their natural resonant frequency can be found by using an adjustable sine wave generator and a fullrange speaker. Simply sweep the frequency range on the sine wave generator and record the knock sensors output voltage. It will register the highest reading at its natural resonant frequency.
Depending on the engine size and characteristics, the frequency range where detonation can be heard may vary. For this reason, they tailor the knock sensor range to be most sensitive in this area. This is usually combined with high-pass/low-pass filtering in the ECU so it blocks out frequencies that do not want to be heard.
-Jamie
Old May 19, 2013 | 06:28 PM
Sorry, I should have specified the flat response one's.
Old May 28, 2013 | 08:51 PM
The setup I completed the other nite. Hoping to get a few minutes to put it on this week and test it out, car has been acting weird not wanting to take hardly any timing, something seems awry.
User71421
Dec 4, 2011 12:25 AM
mshilto89
Mid-Atlantic Region
Apr 29, 2011 06:38 PM
Deannn
Evo X Dyno Results
Mar 28, 2009 05:48 PM
jid2
Jan 22, 2009 06:56 PM
