Running duel maps
Old Nov 7, 2011 | 01:31 PM
05evoGSR's Avatar
Running duel maps
I’ve had meth on my car for over 4 years now and 60k+ miles and don’t trust the system as much anymore (everything still works though) and the car does have 100k on it. My problem is that I don’t want to lose my meth tune but would like to switch to a non-meth safe map when I want to. My questions are as follows:
- Would using a laptop and tactrix cable be the best option to switch maps? If so what program do I need on the laptop to do this? I am not that computer savvy but can do the basics if needed. I have also been out of the evo community for a while now and not sure what people are using anymore.
- If I switch the maps, will I end up losing the map that has been programmed to my ECU by the last tuner with the meth? Is there any way to save this before I switch it?
- Is there a place to get free base maps for just bolt ons? I really don’t have the funds to spend $400.00 on a base tune at my local shop. Mods are in my sig.
Thanks guys.
Old Nov 7, 2011 | 02:58 PM
Raptord's Avatar
Yes you can save the current map that's on the car. The ideal solution for your situation would be to use Tephra v7's alt-maps to have both a "no-meth" map and a "meth" map and be able to switch between them without having to reflash the ECU every time you want to switch.
Old Nov 8, 2011 | 08:19 AM
05evoGSR's Avatar
Thanks Raptord. Can you give me a few good links to point me in the right direction with what you said above? I can rip an engine apart and put it back together but when it comes to the ECU I a newb lol.
Old Nov 8, 2011 | 08:29 AM
Raptord's Avatar
https://www.evolutionm.net/forums/ec...hramod-v7.html
That should get you started. If you're like I was when I was starting out you probably still won't be too sure what to do after reading that; if that's the case feel free to send me a pm and I'll try to guide you along.
