SD: evoscan: how to log iat ?
Old Dec 3, 2011 | 05:34 AM
charlie.tunah's Avatar
definitely check it 1st thing before you start it up. Otherwise other factors are probably raising iat.
Old Dec 5, 2011 | 03:52 AM
211Ratsbud's Avatar
That read 80*. Def not right its 37-40* here in nny
Old Dec 5, 2011 | 05:26 AM
donner's Avatar
Can you measure voltage on your IAT pin? IAT scaling is lookup table for voltage and it returns temperature in celcius degrees. Lets see what yours return.
Old Dec 5, 2011 | 05:39 AM
211Ratsbud's Avatar
As in multi meter correct ? Could I poke the wires right at the sensor ?
Old Dec 5, 2011 | 05:40 AM
211Ratsbud's Avatar
Will do that later today
Old Dec 5, 2011 | 11:54 AM
211Ratsbud's Avatar
2.31 vdc with the car off.(ignition on)
45*f
Old Dec 5, 2011 | 01:28 PM
donner's Avatar
I have test bench IX ecu and also GM IAT sensor. I tested this with rom I sent you and for me it works, I get 20 C degrees from GM sensor (MUT 11) at room temperature 21.5C (room temp measured with Fluke + thermocouple sensor). I measured voltage too and it was 2.65V which matches exactly iat scaling table as expected. I was using normal maf air temp pin as sensor input as probably you too as you have harness for that. In your case at 45F=7C voltage we expect should be around 3.2V. So I have no idea what going on as scaling itself should work right, we have used this in couple of sd cars and it is exactly the same as in prepatched sd2.0 roms.
Old Dec 5, 2011 | 02:02 PM
where are you measuring 211? Could it be a bad wire/ground?
Though, Im guessing that it would measure low, instead of high, if it was a bad connection somewhere.
Just throwing this out there....Dont know what your situation is as far as needing to get the car running (or whether its running as is, or whether you also still have the maf installed). But if you needed to, you could just use the fuel temp sensor temporarily. Alot of ppl use it instead of using a real IAT.
Old Dec 5, 2011 | 02:19 PM
211Ratsbud's Avatar
Measured at the sensor
Old Dec 5, 2011 | 02:55 PM
211Ratsbud's Avatar
Wonder if I have a bad sensor..
Old Dec 5, 2011 | 04:18 PM
211Ratsbud's Avatar
How to change scaling from celsius > *f in the Rom ?
Old Dec 5, 2011 | 11:10 PM
donner's Avatar
This is what I'm using:
<scaling name="TempScale" units="Celsius" toexpr="x" frexpr="x" format="%.0f" min="-40" max="140" inc="1" storagetype="int8" endian="big"/>
<scaling name="TempScale_F" units="Fahrenheit" toexpr="(9/5)*x+32" frexpr="(5/9)*(x-32)" format="%.0f" min="-30" max="900" inc="1" storagetype="int8" endian="big"/>
<scaling name="Volts16" units="Volts" toexpr="x*5/255" frexpr="x*255/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
Then just decide which scaling to use in table (change TempScale to match your unit):
<table name="SD MAT Scaling for IAT Scaling Table" category="Speed Density Programming" address="b070" type="2D" level="1" scaling="TempScale">
<table name="MAT Sensor ADC volts" address="b106" type="Y Axis" elements="139" scaling="Volts16"/>
</table>
Old Dec 6, 2011 | 09:02 AM
211Ratsbud's Avatar
I Ordred a new sensor .. from NAPA .. since the values never changed much I'm going to try that
Old Dec 9, 2011 | 06:21 PM
211Ratsbud's Avatar
New sensor fixed problem!!!!!
Old Dec 9, 2011 | 11:40 PM
donner's Avatar
Which scaling do you use now?
